Hi all,
I would like to know if it is possible to have kapacitor to trigger alert when the threshold was breach for x amount of duration.
I have try StateDuration but it doesn’t seem to be the right one to use it.
Example:
I would like kapacitor to only send alert when CPU usage breach 80% threshold for a duration of 5 minutes.
Hi I’m wondering about the same issue, have you found a solution?
Back then yes. You will need to create a custome TICK script for that.
However i unable to share the solution because i no longer have access to the code.
This however it is smth similar.You can take a look.
