There is an issue where the “COPY TO CLIPBOARD” function when creating tokens does not copy the token to the clipboard:
Hello @oneofthemany,
What version of InfluxDB are you using?
Is this behavior consistent? I’ve never run into this problem.
Hi @Anaisdg,
I’m running v2.6.1 in a container.
I’ll update later with server and frontend information
