As from the README state that it is now supported for resource pool metric, I’ve seen that resource pool metric
refer to this #6782
Configuration from README file https://github.com/influxdata/telegraf/blob/master/plugins/inputs/vsphere/README.md
## Resource Pools
# datastore_include = [ "/*/host/**"] # Inventory path to datastores to collect (by default all are collected)
# datastore_exclude = [] # Inventory paths to exclude
# datastore_metric_include = [] ## if omitted or empty, all metrics are collected
# datastore_metric_exclude = [] ## Nothing excluded by default
# datastore_instances = false ## false by default
## Datastores
# datastore_include = [ "/*/datastore/**"] # Inventory path to datastores to collect (by default all are collected)
Logs from Telegraf
telegraf | 2023-04-27T03:39:34Z I! Loading config: /etc/telegraf/telegraf.d/vsphere-metrics.conf
telegraf | 2023-04-27T03:39:34Z E! error loading config file /etc/telegraf/telegraf.d/vsphere-metrics.conf: error parsing data: line 150: key 'datastore_metric_include' is in conflict with line 82d
telegraf exited with code 1
which means that it’s the duplicate attribute on the configuration file, what is the exact name should I use to be able to gather resource pool metrics? https://github.com/influxdata/telegraf/blob/master/plugins/inputs/vsphere/METRICS.md#resource-pool-metrics
