Telegraf writes to DB, but DB is empty
My windows machine is configured with telegraf 1.15.2 and seems to be working fine. But when I go into chronograf and try to explore on the database it’s empty.
While running telegraf in debug i can see it reporting that it keeps writing 15 metrics every 10 seconds, so i’m not sure where they’re going.
if i go into chronograf and straight up delete the db the debug on the windows machine gives me a 404 in the debug, creates the db again, and the new db is still empty.
Crack open your Telegraf config and take a look at the [[output]] section…
Also, check your Chronograf data source connection…is it connected to the same InfluxDB instance that Telegraf is pointing to?
I did. And both have to be correct since when i delete the DB with chronograf, the debug in telegraf complains with a 404, recreates the db and goes back to writing metrics
Here’s a screenshot from the debug showing it is writing, then i deleted the DB in chronograf and it complained. then recreated the DB and keeps on chugging like nothing is wrong.
@tim.hall
Here is a screenshot of chronograf with the empty DB:
Could it be a timezone issue?
Did you run a select count(*) where time > now() - 1d ?
do i run that in chronograf? I get an error:
you don’t appear to have any measurements…even if the database is re-created. (at least not from this image, perhaps?) What I was trying to see is if any data is landing into a specific database.retention-policy.measurement combination.
but in the example I provided…you should add your from clause
from shOOVR.autogen.??
but the ?? should be a measurement to determine if data is landing. But, if you don’t see any measurements…then for sure, there isn’t any data landing.
what Telegraf plugin(s) are you using and can you share a scrubbed version of your Telegraf config?
I see your debug output from Telegraf (and it looks like there are a small number of metrics being written…) You can also get a quick read on what Telegraf is writing by using the --test flag.
That would show which measurement should be receiving the metrics.
here’s my telegraf config. it’s in windows, nothing fancy in here as i’m just trying to get it to work. at the bottom is the output of the test. I can see it’s collecting data, i can see that i’t writing data, but i’m at a complete loss. im tempted to nuke windows and start all over.
also this may be relavent… this was working fine on my old machine… but i upgraded it. and when i say upgraded, i mean i took the os drive out of it and put it in a new machine and installed drivers.
# Telegraf Configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Environment variables can be used anywhere in this config file, simply surround
# them with ${}. For strings the variable must be within quotes (ie, "${STR_VAR}"),
# for numbers and booleans they should be plain (ie, ${INT_VAR}, ${BOOL_VAR})
# Global tags can be specified here in key="value" format.
[global_tags]
  # dc = "us-east-1" # will tag all metrics with dc=us-east-1
  # rack = "1a"
  ## Environment variables can be used as tags, and throughout the config file
  # user = "$USER"
[agent]
  interval = "10s"
  ## Rounds collection interval to 'interval'
  round_interval = true
  ## Telegraf will send metrics to outputs in batches of at most
  ## metric_batch_size metrics.
  ## This controls the size of writes that Telegraf sends to output plugins.
  metric_batch_size = 1000
  ## Maximum number of unwritten metrics per output.  Increasing this value
  ## allows for longer periods of output downtime without dropping metrics at the
  ## cost of higher maximum memory usage.
  metric_buffer_limit = 10000
  collection_jitter = "0s"
  ## Default flushing interval for all outputs. Maximum flush_interval will be
  ## flush_interval + flush_jitter
  flush_interval = "10s"
  ## Jitter the flush interval by a random amount. This is primarily to avoid
  ## large write spikes for users running a large number of telegraf instances.
  ## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
  flush_jitter = "0s"
  ## By default or when set to "0s", precision will be set to the same
  ## timestamp order as the collection interval, with the maximum being 1s.
  ##   ie, when interval = "10s", precision will be "1s"
  ##       when interval = "250ms", precision will be "1ms"
  ## Precision will NOT be used for service inputs. It is up to each individual
  ## service input to set the timestamp at the appropriate precision.
  ## Valid time units are "ns", "us" (or "µs"), "ms", "s".
  precision = ""
  ## Log at debug level.
  # debug = false
  ## Log only error level messages.
  # quiet = false
  ## Log target controls the destination for logs and can be one of "file",
  ## "stderr" or, on Windows, "eventlog".  When set to "file", the output file
  ## is determined by the "logfile" setting.
  # logtarget = "file"
  ## Name of the file to be logged to when using the "file" logtarget.  If set to
  ## the empty string then logs are written to stderr.
  # logfile = ""
  ## The logfile will be rotated after the time interval specified.  When set
  ## to 0 no time based rotation is performed.  Logs are rotated only when
  ## written to, if there is no log activity rotation may be delayed.
  # logfile_rotation_interval = "0d"
  ## The logfile will be rotated when it becomes larger than the specified
  ## size.  When set to 0 no size based rotation is performed.
  # logfile_rotation_max_size = "0MB"
  ## Maximum number of rotated archives to keep, any older logs are deleted.
  ## If set to -1, no archives are removed.
  # logfile_rotation_max_archives = 5
  ## Override default hostname, if empty use os.Hostname()
  hostname = ""
  omit_hostname = false
#                            OUTPUT PLUGINS                                   #
# Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
  ## The full HTTP or UDP URL for your InfluxDB instance.
  # urls = ["unix:///var/run/influxdb.sock"]
  # urls = ["udp://127.0.0.1:8089"]
  urls = ["http://192.168.1.100:8086"]
  ## The target database for metrics; will be created as needed.
  ## For UDP url endpoint database needs to be configured on server side.
  database = "ShOOVR"
  ## The value of this tag will be used to determine the database.  If this
  ## tag is not set the 'database' option is used as the default.
  database_tag = "shootag"
  ## If true, the 'database_tag' will not be included in the written metric.
  # exclude_database_tag = false
  ## If true, no CREATE DATABASE queries will be sent.  Set to true when using
  ## Telegraf with a user without permissions to create databases or when the
  ## database already exists.
  # skip_database_creation = false
  ## Name of existing retention policy to write to.  Empty string writes to
  ## the default retention policy.  Only takes effect when using HTTP.
  # retention_policy = ""
  ## The value of this tag will be used to determine the retention policy.  If this
  ## tag is not set the 'retention_policy' option is used as the default.
  # retention_policy_tag = ""
  ## If true, the 'retention_policy_tag' will not be included in the written metric.
  # exclude_retention_policy_tag = false
  ## Write consistency (clusters only), can be: "any", "one", "quorum", "all".
  ## Only takes effect when using HTTP.
  # write_consistency = "any"
  ## Timeout for HTTP messages.
  # timeout = "5s"
  ## HTTP Basic Auth
  # username = "telegraf"
  # password = "metricsmetricsmetricsmetrics"
  ## HTTP User-Agent
  # user_agent = "telegraf"
  ## UDP payload size is the maximum packet size to send.
  # udp_payload = "512B"
  ## Optional TLS Config for use on HTTP connections.
  # tls_ca = "/etc/telegraf/ca.pem"
  # tls_cert = "/etc/telegraf/cert.pem"
  # tls_key = "/etc/telegraf/key.pem"
  ## Use TLS but skip chain & host verification
  ## HTTP Proxy override, if unset values the standard proxy environment
  ## variables are consulted to determine which proxy, if any, should be used.
  # http_proxy = "http://corporate.proxy:3128"
  ## Additional HTTP headers
  # http_headers = {"X-Special-Header" = "Special-Value"}
  ## HTTP Content-Encoding for write request body, can be set to "gzip" to
  ## compress body or "identity" to apply no encoding.
  # content_encoding = "identity"
  ## When true, Telegraf will output unsigned integers as unsigned values,
  ## i.e.: "42u".  You will need a version of InfluxDB supporting unsigned
  ## integer values.  Enabling this option will result in field type errors if
  ## existing data has been written.
  # influx_uint_support = false
# # Configuration for sending metrics to InfluxDB
# [[outputs.influxdb_v2]]
#   ## The URLs of the InfluxDB cluster nodes.
#   ## Multiple URLs can be specified for a single cluster, only ONE of the
#   ## urls will be written to each interval.
#   ##   ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
#   urls = ["http://127.0.0.1:9999"]
#   ## Token for authentication.
#   token = ""
#   ## Organization is the name of the organization you wish to write to; must exist.
#   organization = ""
#   ## Destination bucket to write into.
#   bucket = ""
#   ## The value of this tag will be used to determine the bucket.  If this
#   ## tag is not set the 'bucket' option is used as the default.
#   # bucket_tag = ""
#   ## If true, the bucket tag will not be added to the metric.
#   # exclude_bucket_tag = false
#   ## Timeout for HTTP messages.
#   # timeout = "5s"
#   ## Additional HTTP headers
#   # http_headers = {"X-Special-Header" = "Special-Value"}
#   ## HTTP Proxy override, if unset values the standard proxy environment
#   ## variables are consulted to determine which proxy, if any, should be used.
#   # http_proxy = "http://corporate.proxy:3128"
#   ## HTTP User-Agent
#   # user_agent = "telegraf"
#   ## Content-Encoding for write request body, can be set to "gzip" to
#   ## compress body or "identity" to apply no encoding.
#   # content_encoding = "gzip"
#   ## Enable or disable uint support for writing uints influxdb 2.0.
#   # influx_uint_support = false
#   ## Optional TLS Config for use on HTTP connections.
#   # tls_ca = "/etc/telegraf/ca.pem"
#   # tls_cert = "/etc/telegraf/cert.pem"
#   # tls_key = "/etc/telegraf/key.pem"
#   ## Use TLS but skip chain & host verification
#   # insecure_skip_verify = false
#                            INPUT PLUGINS                                    #
# Windows Performance Counters plugin.
# These are the recommended method of monitoring system metrics on windows,
# as the regular system plugins (inputs.cpu, inputs.mem, etc.) rely on WMI,
# which utilize more system resources.
# See more configuration examples at:
#   https://github.com/influxdata/telegraf/tree/master/plugins/inputs/win_perf_counters
[[inputs.win_perf_counters]]
  [[inputs.win_perf_counters.object]]
    # Processor usage, alternative to native, reports on a per core.
    ObjectName = "Processor"
    Instances = ["*"]
    Counters = [
      "% Idle Time",
      "% Interrupt Time",
      "% Privileged Time",
      "% User Time",
      "% Processor Time",
      "% DPC Time",
    Measurement = "win_cpu"
    # Set to true to include _Total instance when querying for all (*).
    IncludeTotal=true
    # Disk times and queues
    ObjectName = "LogicalDisk"
    Instances = ["*"]
    Counters = [
      "% Idle Time",
      "% Disk Time",
      "% Disk Read Time",
      "% Disk Write Time",
      "% Free Space",
      "Current Disk Queue Length",
      "Free Megabytes",
    Measurement = "win_disk"
    #IncludeTotal=false
    ObjectName = "PhysicalDisk"
    Instances = ["*"]
    Counters = [
      "Disk Read Bytes/sec",
      "Disk Write Bytes/sec",
      "Disk Reads/sec",
      "Disk Writes/sec",
      "% Disk Time",
      "% Disk Read Time",
    Measurement = "win_diskio"
    ObjectName = "Network Interface"
    Instances = ["*"]
    Counters = [
      "Bytes Received/sec",
      "Bytes Sent/sec",
      "Packets Received/sec",
      "Packets Sent/sec",
      "Packets Received Discarded",
      "Packets Outbound Discarded",
      "Packets Received Errors",
      "Packets Outbound Errors",
    Measurement = "win_net"
    ObjectName = "System"
    Counters = [
      "Context Switches/sec",
      "System Calls/sec",
      "Processor Queue Length",
      "System Up Time",
    Instances = ["------"]
    Measurement = "win_system"
    #IncludeTotal=false
    # Example query where the Instance portion must be removed to get data back,
    # such as from the Memory object.
    ObjectName = "Memory"
    Counters = [
      "Available Bytes",
      "Cache Faults/sec",
      "Demand Zero Faults/sec",
      "Page Faults/sec",
      "Pages/sec",
      "Transition Faults/sec",
      "Pool Nonpaged Bytes",
      "Pool Paged Bytes",
      "Standby Cache Reserve Bytes",
      "Standby Cache Normal Priority Bytes",
      "Standby Cache Core Bytes",
    # Use 6 x - to remove the Instance bit from the query.
    Measurement = "win_mem"
    #IncludeTotal=false
    # such as from the Paging File object.
    ObjectName = "Paging File"
    Counters = [
      "% Usage",
    Instances = ["_Total"]
    Measurement = "win_swap"
# Windows system plugins using WMI (disabled by default, using
# win_perf_counters over WMI is recommended)
# # Read metrics about cpu usage
# [[inputs.cpu]]
#   ## Whether to report per-cpu stats or not
#   percpu = true
#   ## Whether to report total system cpu stats or not
#   totalcpu = true
#   ## If true, collect raw CPU time metrics.
#   collect_cpu_time = false
#   ## If true, compute and report the sum of all non-idle CPU states.
#   report_active = false
# # Read metrics about disk usage by mount point
# [[inputs.disk]]
#   ## By default stats will be gathered for all mount points.
#   ## Set mount_points will restrict the stats to only the specified mount points.
#   # mount_points = ["/"]
#   ## Ignore mount points by filesystem type.
#   ignore_fs = ["tmpfs", "devtmpfs", "devfs", "overlay", "aufs", "squashfs"]
# # Read metrics about disk IO by device
# [[inputs.diskio]]
#   ## By default, telegraf will gather stats for all devices including
#   ## disk partitions.
#   ## Setting devices will restrict the stats to the specified devices.
#   # devices = ["sda", "sdb", "vd*"]
#   ## Uncomment the following line if you need disk serial numbers.
#   # skip_serial_number = false
#   ## On systems which support it, device metadata can be added in the form of
#   ## tags.
#   ## Currently only Linux is supported via udev properties. You can view
#   ## available properties for a device by running:
#   ## 'udevadm info -q property -n /dev/sda'
#   # device_tags = ["ID_FS_TYPE", "ID_FS_USAGE"]
#   ## Using the same metadata source as device_tags, you can also customize the
#   ## name of the device via templates.
#   ## The 'name_templates' parameter is a list of templates to try and apply to
#   ## the device. The template may contain variables in the form of '$PROPERTY' or
#   ## '${PROPERTY}'. The first template which does not contain any variables not
#   ## present for the device is used as the device name tag.
#   ## The typical use case is for LVM volumes, to get the VG/LV name instead of
#   ## the near-meaningless DM-0 name.
#   # name_templates = ["$ID_FS_LABEL","$DM_VG_NAME/$DM_LV_NAME"]
# # Read metrics about memory usage
# [[inputs.mem]]
#   # no configuration
# # Read metrics about swap memory usage
# [[inputs.swap]]
and here’s the output of the --test
ok…last two things to check.
  1. comment out the database_tag line in your telegraf config. You have both the database and database_tag set…along with the exclude_database_tag = false (default). Something about that setup doesn’t seem correct.
  2. is the database actually running at the IP/port listed? It looks like you are on a locally mapped network because of 192.168.x.y. The local ip might change when you stop/start/reboot your machine on that network.
nope… that didn’t work either. yes influx is actually running in docker on a server in my network. I don’t know whats going on, but i don’t have time to fight with it anymore.
I actually ended up just installing influx on the windows box and connecting it a new datasource. thanks for your help
