Telegraf won’t send inputs.docker metrics correctly to questdb
Hi try to send inputs.docker via telegraf to questdb but got this error in questdb:
2024-11-02T13:43:11.605205Z E i.q.c.l.t.LineTcpMeasurementScheduler could not create table [tableName=docker_container_status, errno=-102, ex=table is dropped [dirName=docker_container_status~42543, tableName=docker_container_status]] 2024-11-02T13:43:11.605242Z E i.q.c.l.t.LineTcpConnectionContext [372] could not parse measurement, NONE at 430, line (may be mangled due to partial parsing): ‘docker_container_status,container_image=bfabbaf5985e,container_name=mycontainername,container_status=running,container_version=unknown,engine_host=deploy,host=deploy,io.buildah.version=1.33.8,server_version=4.9.4-rhel container_id=“d4f707e96dcefcf0066eff54d70c4b122bf6f1ed50e1f4df71cadb2cad701da7”,started_at=1730550764250914871i,uptime_ns=4216199399846i,oomkilled=false,pid=10525i,exitcode=0i,restart_count=0i 1730554980000000000’
Here is the plugin repo:
telegraf send output:
[[outputs.socket_writer]]
address = “tcp://192.168.1.1:9009” (edited)
Any idea?
It seems like QuestDB suggests to use the influxdb_v2 output… See documentation.
