Bug report
Trying to collect docker container metrics using Grafana-Influxdb-Telegraf on Windows 10, but Telegraf throws error
Relevant telegraf.conf: DOCKER INPUT PLUGIN telegraf.conf -
[[inputs.docker]]
# ## Docker Endpoint
# ## To use TCP, set endpoint = "tcp://[ip]:[port]"
# ## To use environment variables (ie, docker-machine), set endpoint = "ENV"
# endpoint = "unix:///var/run/docker.sock"
endpoint = "localhost:2375"
# ## Only collect metrics for these containers, collect all if empty
container_names = []
# ## Containers to include and exclude. Globs accepted.
# ## Note that an empty array for both will include all containers
container_name_include = []
container_name_exclude = []
# ## Timeout for docker list, info, and stats commands
timeout = "5s"
System info:
Windows-10-Pro-64-bit
docker CE 17.x
Using telegraf Repo-official (v1.3)
InfluxDB - official Repo
Steps to reproduce:
Uncommented inputs.docker to timeout, as mentioned above
copied telegraf.conf from host to container.
Error 1 : influxdb on localhost:8086 not recognized, by telegraf container
Log : Database creation failed: Post http://localhost:8086-query?q=CREATE+DATABASE+%22telegraf%22: dial tcp 127.0.0.1:8086: getsockopt: connection refused
Error 2 : 2017/09/29 18:10:25 I! Using config file: /etc/telegraf/telegraf.conf
2017-09-29T18:10:25Z I! Database creation failed: Post http://localhost:8086-query?q=CREATE+DATABASE+%22telegraf%22: dial tcp 127.0.0.1:8086: getsockopt: connection refused
2017-09-29T18:10:25Z I! Starting Telegraf v1.4.1
2017-09-29T18:10:25Z I! Loaded outputs: influxdb
2017-09-29T18:10:25Z I! Loaded inputs: inputs.kernel inputs.mem inputs.processes inputs.swap inputs.system inputs.cpu inputs.disk inputs.diskio inputs.docker
2017-09-29T18:10:25Z I! Tags enabled: host=c9a2e52355d4
2017-09-29T18:10:25Z I! Agent Config: Interval:10s, Quiet:false, Hostname:“c9a2e52355d4”, Flush Interval:10s
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x38 pc=0xb3ec17]
goroutine 28 [running]:
github.com-influxdata/telegraf/plugins/inputs/docker.(*Docker).gatherInfo(0xc042166480, 0x1c8ae00, 0xc0422788c0, 0x0, 0x0)
/home/ubuntu/telegraf-build/src/github.com-influxdata/telegraf/plugins/inputs/docker/docker.go:198 +0x15e
github.com-influxdata/telegraf/plugins/inputs/docker.(*Docker).Gather(0xc042166480, 0x1c8ae00, 0xc0422788c0, 0x0, 0x0)
/home/ubuntu/telegraf-build/src/github.com-influxdata/telegraf/plugins/inputs/docker/docker.go:158 +0x9b
github.com-influxdata/telegraf/agent.gatherWithTimeout.func1(0xc04239e2a0, 0xc04210c9c0, 0xc0422788c0)
/home/ubuntu/telegraf-build/src/github.com/influxdata/telegraf/agent/agent.go:153 +0x50
created by github.com-influxdata/telegraf/agent.gatherWithTimeout
/home/ubuntu/telegraf-build/src/github.com/influxdata/telegraf/agent/agent.go:154 +0xd3
Expected behavior:
All running “Docker Linux containers” on Docker CE(Windows) metrics should be collected by Telegraf
Actual behavior:
Telegraf collects only host information/stats
Additional info: docker commands used
docker cp telegraf:\etc\telegraf\telegraf.conf .\deuce\telegraf.conf
–>cd deuce
docker cp telegraf.conf telegraf:\etc\telegraf\telegraf.conf
docker logs telegraf
docker run -d --net=container:influxdb telegraf
Feature Request
Telegraf.conf file for windows 10 is needed. A readymade file in windows for enabling all container metrics should be supplied. different
Opening a feature request kicks off a discussion.
Proposal:
Current behavior:
Desired behavior:
Use case: [Why is this important (helps with prioritizing requests)]
telegraf.conf.txt
daniel
October 2, 2017, 7:21pm
2
This is a bug, thank you for opening an issue
opened 06:53PM - 29 Sep 17 UTC
closed 06:51PM - 28 Jul 22 UTC
bug
platform/windows
area/docker
## Bug report
Trying to collect docker container metrics using Grafana-Influxdb… -Telegraf on Windows 10, but Telegraf throws error
### Relevant telegraf.conf: DOCKER INPUT PLUGIN telegraf.conf -
[[inputs.docker]]
timeout = "5s"
### System info:
docker CE 17.x
### Steps to reproduce:
1. Uncommented inputs.docker to timeout, as mentioned above
2. copied telegraf.conf from host to container.
3. Error 1 : influxdb on localhost:8086 not recognized, by telegraf container
Log : Database creation failed: Post http://localhost:8086/query?q=CREATE+DATABASE+%22telegraf%22: dial tcp 127.0.0.1:8086: getsockopt: connection refused
4. Error 2 : 2017/09/29 18:10:25 I! Using config file: /etc/telegraf/telegraf.conf
2017-09-29T18:10:25Z I! Database creation failed: Post http://localhost:8086/query?q=CREATE+DATABASE+%22telegraf%22: dial tcp 127.0.0.1:8086: getsockopt: connection refused
2017-09-29T18:10:25Z I! Agent Config: Interval:10s, Quiet:false, Hostname:"c9a2e52355d4", Flush Interval:10s
### Expected behavior:
All running "Docker Linux containers" on Docker CE(Windows) metrics should be collected by Telegraf
### Actual behavior:
### Additional info: docker commands used
-->cd deuce
## Feature Request
### Proposal:
### Current behavior:
### Desired behavior:
### Use case: [Why is this important (helps with prioritizing requests)]
[telegraf.conf.txt](https://github.com/influxdata/telegraf/files/1345359/telegraf.conf.txt)
beatopc
December 19, 2021, 1:41pm
3
This was opened 4 years ago and there’s still no file for windows and we spend hours to try to configure it to work on windows 10…
jpowers
December 20, 2021, 5:22pm
4
@beatopc
If this is something you want fixed can you reply on the bug itself and even better reproduce with the latest version of Telegraf. Getting the full crash trace on the latest version would help us determine where the issue more quickly.
Thanks!
