I am having a trivial bug that I wanted to preset.
I am using telegraf (1.25.3, but same issue on 1.22.1) on Windows 10.
I write to a remote influxdb via http configured in the outputs section. As shown below local host is not configured as an output, unless I am missing something. However in the logs, I constantly get failures to write to localhost.
The weirdest part is that the data ends up in the right influx database and shows just fine in Grafana. I have no idea where the localhost is coming from.
# Telegraf Configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Environment variables can be used anywhere in this config file, simply surround
# them with ${}. For strings the variable must be within quotes (ie, "${STR_VAR}"),
# for numbers and booleans they should be plain (ie, ${INT_VAR}, ${BOOL_VAR})
# Global tags can be specified here in key="value" format.
[global_tags]
# dc = "us-east-1" # will tag all metrics with dc=us-east-1
# rack = "1a"
## Environment variables can be used as tags, and throughout the config file
# user = "$USER"
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Log at debug level.
debug = true
## Log only error level messages.
# quiet = false
## Log target controls the destination for logs and can be one of "file",
## "stderr" or, on Windows, "eventlog". When set to "file", the output file
## is determined by the "logfile" setting.
logtarget = "file"
## Name of the file to be logged to when using the "file" logtarget. If set to
## the empty string then logs are written to stderr.
logfile = "C:\\Program Files\\Telegraf\\telegraf.log"
## The logfile will be rotated after the time interval specified. When set
## to 0 no time based rotation is performed. Logs are rotated only when
## written to, if there is no log activity rotation may be delayed.
# logfile_rotation_interval = "0d"
## The logfile will be rotated when it becomes larger than the specified
## size. When set to 0 no size based rotation is performed.
# logfile_rotation_max_size = "0MB"
## Maximum number of rotated archives to keep, any older logs are deleted.
## If set to -1, no archives are removed.
# logfile_rotation_max_archives = 5
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
# OUTPUT PLUGINS #
# Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
## The full HTTP or UDP URL for your InfluxDB instance.
urls = ["http://10.0.20.45:8086"]
## The target database for metrics; will be created as needed.
## For UDP url endpoint database needs to be configured on server side.
database = "BattleStation"
## If true, no CREATE DATABASE queries will be sent. Set to true when using
## Telegraf with a user without permissions to create databases or when the
## database already exists.
skip_database_creation = true
## Name of existing retention policy to write to. Empty string writes to
## the default retention policy. Only takes effect when using HTTP.
retention_policy = ""
## Timeout for HTTP messages.
# timeout = "5s"
## HTTP Basic Auth
username = "*********"
password = "*******"
## HTTP User-Agent
user_agent = "telegraf"
## UDP payload size is the maximum packet size to send.
udp_payload = "512B"
2023-03-07T21:44:02Z I! Starting Telegraf 1.25.3
2023-03-07T21:44:02Z I! Available plugins: 210 inputs, 9 aggregators, 26 processors, 21 parsers, 57 outputs, 2 secret-stores
2023-03-07T21:44:02Z I! Loaded inputs: win_perf_counters (3x)
2023-03-07T21:44:02Z I! Loaded aggregators:
2023-03-07T21:44:02Z I! Loaded processors:
2023-03-07T21:44:02Z I! Loaded secretstores:
2023-03-07T21:44:02Z I! Loaded outputs: influxdb (3x)
2023-03-07T21:44:02Z I! Tags enabled: host=Battlestation
2023-03-07T21:44:02Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"Battlestation", Flush Interval:10s
2023-03-07T21:44:02Z D! [agent] Initializing plugins
2023-03-07T21:44:02Z D! [agent] Connecting outputs
2023-03-07T21:44:02Z D! [agent] Attempting connection to [outputs.influxdb]
2023-03-07T21:44:02Z D! [agent] Successfully connected to outputs.influxdb
2023-03-07T21:44:02Z D! [agent] Starting service inputs
2023-03-07T21:44:12Z D! [outputs.influxdb] Wrote batch of 429 metrics in 23.0855ms
2023-03-07T21:44:12Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
2023-03-07T21:44:12Z D! [outputs.influxdb] Wrote batch of 429 metrics in 29.6106ms
2023-03-07T21:44:14Z E! [outputs.influxdb] When writing to [http://localhost:8086]: failed doing req: Post "http://localhost:8086/write?db=BattleStation": dial tcp [::1]:8086: connectex: No connection could be made because the target machine actively refused it.
2023-03-07T21:44:14Z D! [outputs.influxdb] Buffer fullness: 429 / 10000 metrics
2023-03-07T21:44:14Z E! [agent] Error writing to outputs.influxdb: could not write any address
2023-03-07T21:44:22Z D! [outputs.influxdb] Wrote batch of 429 metrics in 19.6201ms
2023-03-07T21:44:22Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
2023-03-07T21:44:22Z D! [outputs.influxdb] Wrote batch of 429 metrics in 26.2594ms
2023-03-07T21:44:24Z E! [outputs.influxdb] When writing to [http://localhost:8086]: failed doing req: Post "http://localhost:8086/write?db=BattleStation": dial tcp [::1]:8086: connectex: No connection could be made because the target machine actively refused it.
2023-03-07T21:44:24Z D! [outputs.influxdb] Buffer fullness: 858 / 10000 metrics
2023-03-07T21:44:24Z E! [agent] Error writing to outputs.influxdb: could not write any address
2023-03-07T21:44:32Z D! [outputs.influxdb] Wrote batch of 429 metrics in 20.4369ms
2023-03-07T21:44:32Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
2023-03-07T21:44:32Z D! [outputs.influxdb] Wrote batch of 429 metrics in 20.9518ms
2023-03-07T21:44:34Z E! [outputs.influxdb] When writing to [http://localhost:8086]: failed doing req: Post "http://localhost:8086/write?db=BattleStation": dial tcp [::1]:8086: connectex: No connection could be made because the target machine actively refused it.
2023-03-07T21:44:34Z D! [outputs.influxdb] Buffer fullness: 1287 / 10000 metrics
2023-03-07T21:44:34Z E! [agent] Error writing to outputs.influxdb: could not write any address
2023-03-07T21:44:42Z D! [outputs.influxdb] Wrote batch of 429 metrics in 22.7816ms
2023-03-07T21:44:42Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
2023-03-07T21:44:42Z D! [outputs.influxdb] Wrote batch of 429 metrics in 27.2103ms
2023-03-07T21:44:44Z E! [outputs.influxdb] When writing to [http://localhost:8086]: failed doing req: Post "http://localhost:8086/write?db=BattleStation": dial tcp [::1]:8086: connectex: No connection could be made because the target machine actively refused it.
