Many thanks your reply to my post.
I’ve try read everything about this (include your comments of course in Github), and i 'm not programmer but we are trying evaluate Telegraf as metric collector and we are facing this Index chalaging with diferent tables and i’m just trying understand if this is feasible, and that is the reason i’ve ask for some examples if possible.
If some expert can comment on this i appreciate just to try understand if we are in right or wrong direction.
Problem:
We have one situation of equipment (SAN), that use Two diferent Mibs and return diferent Index:
Exemple:
MIB/OID: FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets (give port performance count In) and in our case have Index 1.1 - 1.8
other
MIB(OID: FCMGMT-MIB::connUnitPortName (give port interface name) and in our case have Index 16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.1 - 8
Objective is map the two OID, somethng that:
Host Name - Port Name - Metric (in this case can be Port Performance)
Like i said i’m not sure this SNMP plugin with “two table merge with diferent index” solve this situation.
In Readme exemple they mention " one table should have translation field that return index", and i i think I don’t have that.
My interpetration is that i need table that must have OID that return value = Index value. Correct or i’m wrong?
If is the case i don’t have any OID that return Index value, i think.
Results:
linux3@linux3-virtual-machine:~/src/telegraf$ snmpbulkwalk -Ob -m FCMGMT-MIB -v2c -cpublic 192.168.1.11 connUnitPOrtName
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.1 = STRING: “Port0”
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.2 = STRING: “Port1”
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.3 = STRING: “Port2”
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.4 = STRING: “Port3”
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.5 = STRING: “Port4”
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.6 = STRING: “Port5”
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.7 = STRING: “Port6”
FCMGMT-MIB::connUnitPortName.16.0.0.3.248.32.18.32.0.0.0.0.0.0.0.0.8 = STRING: “Port7”
linux3@linux3-virtual-machine:~/src/telegraf$ snmpbulkwalk -Ob -m FIBRE-CHANNEL-FE-MIB -v2c -cpublic 192.168.1.11 fcFxPortC3InOctets
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.1 = Counter32: 782383144
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.2 = Counter32: 2426667236
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.3 = Counter32: 3408660756
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.4 = Counter32: 0
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.5 = Counter32: 0
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.6 = Counter32: 0
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.7 = Counter32: 0
FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets.1.8 = Counter32: 0
Telegraf config:
[[inputs.snmp.table]]
name = “Doubletablev2”
index_as_tag = true
[[inputs.snmp.table.field]]
name = "fcFxPortC3InOctets"
oid = "FIBRE-CHANNEL-FE-MIB::fcFxPortC3InOctets"
name = "fcFxPortOperMode"
oid = "FIBRE-CHANNEL-FE-MIB::fcFxPortOperMode" #I know this is not a Index translate field
secondary_index_table = true
name = "connUnitPortName"
oid = "FCMGMT-MIB::connUnitPortName"
secondary_index_use = true
is_tag = true
Telegraf test:
linux3@linux3-virtual-machine:~/src/telegraf$ ./telegraf --config https://westeurope-1.azure.cloud2.influxdata.com/api/v2/telegrafs/08480b399e5d1000 --test
2021-10-12T09:25:38Z I! Starting Telegraf
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.1 fcFxPortC3InOctets=3646977766i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.2 fcFxPortC3InOctets=2426668576i,fcFxPortOperMode=2i 1634030739000000000
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.3 fcFxPortC3InOctets=1059053732i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.4 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.5 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.6 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.7 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.11,host=linux3-virtual-machine,index=1.8 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.2 fcFxPortC3InOctets=2960988964i,fcFxPortOperMode=2i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.3 fcFxPortC3InOctets=95317396i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.4 fcFxPortC3InOctets=1879387052i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.5 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.6 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.7 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.8 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
Doubletablev2,agent_host=192.168.1.12,host=linux3-virtual-machine,index=1.1 fcFxPortC3InOctets=0i,fcFxPortOperMode=1i 1634030739000000000
