I am calling datas from two different snmp tables. One indexes as 1,2,3,… but whereas the other indexes as 10001,10002,10003,… So when I want to merge the two data’s with index_as_tag = true it doesn’t work. Could you give me an idea on how to merge the data. There are no common data’s with the two tables so i couldn’t use secodary table.
How do I get that specific index of a table and fix it because I’ll need the result to be in a single output table so when I use index as tag it would just get one of the index right
Can you share what the two OIDs are? If there are no common pieces to them, I am confused why you would want to merge them
I’ll need to merge the ifinoctects 1.3.6.1.2.1.2.2.1.10 and csubsessionusername .1.3.6.1.4.1.9.9.786.1.1.1.1.24 oids
Checked a few of our devices and didn’t get a hit for one that has the same OID used on them for a comparison. Generally when I have an issue like this I go the route of creating it as a python script and just running it through inputs.exec instead. Thats usually my go to route if it can’t be easily solved with post processing.
