Hi, I’m using Telegraf 1.16.1 to poll SNMP mib of Raritan Power Delivery Unit. It supports PDU2-MIB and I’m interested to poll following table:
PDU2-MIB::pdu2.configuration.outlets.outletConfigurationTable
I know how telegraf SNMP plugin is defined to poll normal tables. However, in this case Telegraf doesn’t regognize this as a table because it has two indexes. One for PDU (I only have one PDU) and one for outlet.
$ snmpwalk -v 2c -c public pdu.lab.something
1.3.6.1.4.1.13742.6.3.5.3
Bad operator (INTEGER): At line 73 in /usr/share/snmp/mibs/ietf/SNMPv2-PDU
PDU2-MIB::outletLabel.1.1 = STRING: 1
PDU2-MIB::outletLabel.1.2 = STRING: 2
PDU2-MIB::outletLabel.1.3 = STRING: 3
--clip--
PDU2-MIB::outletName.1.1 = STRING:
PDU2-MIB::outletName.1.2 = STRING: sdwan3
PDU2-MIB::outletName.1.3 = STRING:
I get following error:
Was that a table? SNMPv2-SMI::enterprises.13742.6.3.5.3: exit status 1
However, snmptable command regognizes table normally and prints headers and content.
ubuntu-user@grafana-vm:~$ snmptable -v 2c -c public pdu.lab.something 1.3.6.1.4.1.13742.6.3.5.3
SNMP table: PDU2-MIB::outletConfigurationTable
outletLabel outletName outletReceptacle outletPoleCount outletRatedVoltage outletRatedCurrent outletRatedVA outletDeviceCapabilities outletPoleCapabilities outletPowerCyclingPowerOffPeriod outletStateOnStartup outletUseGlobalPowerCyclingPowerOffPeriod outletSwitchable outletReceptacleDescriptor outletNonCritical outletSequenceDelay outletPowerSource
1 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
2 sdwan3 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
4 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
5 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
6 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
7 receptacleIEC320C19 2 200-240V 16A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C19 false 0 PDU2-MIB::inletLabel.1.1
8 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
9 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
10 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
11 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
12 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
13 receptacleIEC320C19 2 200-240V 16A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C19 false 0 PDU2-MIB::inletLabel.1.1
14 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
15 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
16 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
17 sdwan5 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
18 sdwan4 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
19 receptacleIEC320C19 2 200-240V 16A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C19 false 0 PDU2-MIB::inletLabel.1.1
20 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
21 sdwan1 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
22 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
23 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
24 receptacleIEC320C13 2 200-240V 10A "9F 04 02 00 00 00 00 " "00 00 00 00 00 00 00 " 10 globalOutletStateOnStartup true true IEC 60320 C13 false 0 PDU2-MIB::inletLabel.1.1
Does telegraf support tables with two index numbers?
Here is my telegraf config:
[[inputs.snmp.table]]
name = "outlet"
inherit_tags = [ "hostname" ]
oid = "1.3.6.1.4.1.13742.6.3.5.3"
#oid = "PDU2-MIB::pdu2.configuration.outlets.outletConfigurationTable"
[[inputs.snmp.table.field]]
name = "outletLabel"
oid = "1.3.6.1.4.1.13742.6.3.5.3.1.2"
is_tag = true
