I am trying to pull some snmp data from telegraf into influxdb and it’s 50% working Here is my explanation/configuration:
I would like to create 2 tables into my telegraf database on influxdb.
[[inputs.snmp]]
agents = [ “IP_1:161”, “IP_2:161” ]
timeout = “5s”
retries = 3
version = 2
community = “my_community”
name = “Cisco CSR 1000v”
interval = “30s”
[[inputs.snmp.field]]
name = “hostname”
oid = “SNMPv2-MIB::sysName.0”
is_tag = true
name = “calls”
oid = “SNMPv2-SMI::enterprises.9.9.63.1.3.8.2.0”
conversion = “int” #is_tag = true#
[[inputs.snmp.table]]
name = “calls” #inherit_tags = [ “hostname” ]
[[inputs.snmp.table.field]]
name = “calls”
name = “interface”
oid = “IF-MIB::ifXTable”
name = “ifDescr”
oid = “IF-MIB::ifDescr”
is_tag = true
This is working, I can see the snmp data being stored into a table CSR 1000 v.
name = “calls”
conversion = “int”
Now if I want to be more specific and put these datas into their own table “calls”. it simply doesn’t work
name = “calls”
Just to test that my config is right … I have tried to create another table “interface” to gather some other data and this is working
name = “interface”
name = “ifDescr”
is_tag = true
I have read tons of documentation today but I am struggling to understand what I am doing wrong here … Can you guys enlighten me ?
When I try to create a table using the following config it fails
name = “calls”
oid = “1.3.6.1.4.1”
I don’t understand why telegraf is telling me that this is not a table
2018-11-20T00:58:29Z E! Error in plugin [inputs.snmp]: initializing table calls: getting table columns: exit status 1: Was that a table? SNMPv2-SMI::enterprises
2018-11-20T00:58:59Z E! Error in plugin [inputs.snmp]: initializing table calls: getting table columns: exit status 1: Was that a table? SNMPv2-SMI::enterprises
When moving the field to a table field, try removing the .0, I think this is a bug in the library we are using where you can’t start and end at the same OID, but I will open an issue to check. At any rate, can you try:
name = "calls"
name = "calls"
oid = "SNMPv2-SMI::enterprises.9.9.63.1.3.8.2"
conversion = "int"
For the example in the second post I think we are off track, what are you trying to do?
Again, I think it is a bug, but the workaround should work when getting a leaf node. These two OIDs basically point to the same object, here is from RFC2578
For leaf objects which are not columnar objects (i.e., not contained
within a conceptual table), instances of the object are identified by
appending a sub-identifier of zero to the name of that object.
Here is the issue I opened with gosnmp, I’m sure they will be able to clarify if this is intentional behavior or not.
