I’m using Telegraf to pool some devices throught SNMP and data are correctly inserted into Influxdb.
Recently I have created this config file to pool a F5 BigIP device but I don’t undrestand why fields aren’t added on InfluxDB :
System
name = “F5_system”
[inputs.snmp.tags]
cluster = “cluster_ASM”
[[inputs.snmp.field]]
name = “hostname”
oid = “RFC1213-MIB::sysName.0”
is_tag = true
name = “FailoverStatus”
oid = “.1.3.6.1.4.1.3375.2.1.14.3.2”
name = “PowerSupplyStatus”
oid = “.1.3.6.1.4.1.3375.2.1.3.2.2.2.1.2”
name = “FanStatus”
oid = “.1.3.6.1.4.1.3375.2.1.3.2.1.2.1.2”
name = “CPUUsage”
oid = “.1.3.6.1.4.1.3375.2.1.7.5.2.1.27”
name = “MemoryUsage”
oid = “.1.3.6.1.4.1.3375.2.1.7.4.2”
When I want to add a new panel on Grafana, I’m unable to find those new measurement (FailoverStatus, PowerSupplyStatus…)
Snmp pooling is working correctly on oids and I have others Telegraf config files based exacly on the same way who are working great.
I figured out yesterday what happened and it seems oid on the original config file wasn’t correct.
So I have used those and now I can see metrics on InfluxDB :
System
name = “f5_system”
[inputs.snmp.tags]
name = “hostname”
is_tag = true
oid = “.1.3.6.1.4.1.3375.2.1.14.3.2.0”
[[inputs.snmp.table]]
name = “virtual_server”
inherit_tags = [ “hostname” ]
oid = “F5-BIGIP-LOCAL-MIB::ltmVirtualServStatTable”
[[inputs.snmp.table.field]]
name = “ltmVirtualServStatName”
oid = “F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName”
oid = “.1.3.6.1.4.1.3375.2.2.10.1.2.1.1”
is_tag = true
name = “ltmVirtualServStatClientCurConns”
oid = “F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientCurConns”
oid = “.1.3.6.1.4.1.3375.2.2.10.2.3.1.12”
name = “ltmVirtualServStatClientBytesIn”
oid = “F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientBytesIn”
oid = “.1.3.6.1.4.1.3375.2.2.10.2.3.1.7”
name = “ltmVirtualServStatClientBytesOut”
oid = “F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientBytesOut”
