Hello All,
I’m running Telegraf 1.14.5 with InfluxDB 1.6.4 on Ubuntu Server 20.04 LTS. The problem I’m having is for some reason telegraf is not collecting SNMP field data into InfluxDB while having no issue with SNMP table types e.g.
# telegraf --input-filter=snmp -config /etc/telegraf/telegraf.d/monitor-fgt01-2.conf --test
2020-07-04T10:09:31Z I! Starting Telegraf 1.14.5
# telegraf --input-filter=snmp -config /etc/telegraf/telegraf.d/monitor-fgt01.conf --test
2020-07-04T10:09:37Z I! Starting Telegraf 1.14.5
> FortigateIF,agent_host=10.0.0.1,host=myfavhost1 ifConnectorPresent=1i,ifCounterDiscontinuityTime=0i,ifHCInBroadcastPkts=0i,ifHCInMulticastPkts=0i,ifHCInOctets=0i,ifHCInUcastPkts=0i,ifHCOutBroadcastPkts=0i,ifHCOutMulticastPkts=0i,ifHCOutOctets=0i,ifHCOutUcastPkts=0i,ifHighSpeed=0i,ifInBroadcastPkts=0i,ifInMulticastPkts=0i,ifLinkUpDownTrapEnable=1i,ifName="port10",ifOutBroadcastPkts=0i,ifOutMulticastPkts=0i,ifPromiscuousMode=2i 1593857379000000000
As you can see the first command returns nothing while the second one has all the values. The none-working configuration is as per below. The header part is the same for both files.
[[inputs.snmp]]
agents = [ "10.0.0.1:161" ]
version = 3
community = "community"
auth_protocol = "sha"
auth_password = "password1"
sec_level = "authPriv"
priv_protocol = "AES"
priv_password = "password1"
sec_name = "user1"
name = "snmp"
# Timeout for each SNMP query.
max_repetitions = 10
timeout = "5s"
# Number of retries to attempt within timeout.
retries = 1
[[inputs.snmp.field]]
name = "hostname"
oid = "RFC1213-MIB::sysName.0"
is_tag = true
name = "sysUpTime"
oid = "FORTINET-FORTIGATE-MIB::fgSysUpTime"
name = "sysVersion"
oid = "FORTINET-FORTIGATE-MIB::fgSysVersion"
name = "sysCpuUsage"
oid = "FORTINET-FORTIGATE-MIB::fgSysCpuUsage"
name = "sysMemUsage"
oid = "FORTINET-FORTIGATE-MIB::fgSysMemUsage"
If I do some snmpwalk manually I get those values back just fine:
# snmpwalk -v3 -l 'authPriv' -a 'SHA' -A 'password1' -u 'user1' -x 'AES' -X 'password1' 10.0.0.1 RFC1213-MIB::sysName.0
SNMPv2-MIB::sysName.0 = STRING: HOMELAB-FGT01
# snmpwalk -v3 -l 'authPriv' -a 'SHA' -A 'password1' -u 'user1' -x 'AES' -X 'password1' 10.0.0.1 FORTINET-FORTIGATE-MIB::fgSysVersion
FORTINET-FORTIGATE-MIB::fgSysVersion.0 = STRING: v6.4.1,build1637,200604 (GA)
In the debug log it appears telegraf is trying its best to query those values (or at least to do snmptranslate on them).
2020-07-04T05:12:31Z D! [inputs.snmp] executing "snmptranslate" "-Td" "-Ob" "RFC1213-MIB::sysName.0"
2020-07-04T05:12:32Z D! [inputs.snmp] executing "snmptranslate" "-Td" "-Ob" "FORTINET-FORTIGATE-MIB::fgSysVersion"
Is there anything else I can do to troubleshoot the issue further, please?
Thank you.
