Hello Team,
I am using the latest version of telegraf : 1.29.4 (git: HEAD@4441c4ed)
I setup the ouputs to influxdb2 with secrets (and it works, I had to create secrets under telegraf user context), I tried to add redfish support with the most basic form with a username and password : it works !
Once I moved out the login & password and switch to telegraf secrets for this input (I also added secrets under my telegraf user context) :
The following error message appears in my log :
E! [inputs.redfish] Error in plugin: received status code 401 (Unauthorized) for address https://ipmi-xxxxxxxxxxxxxx, expected 200
Here is my dedicated input file for redfish :
[[inputs.redfish]]
## Redfish API Base URL.
address = "https://ipmi-ipmi-xxxxxxxxxxxxxx"
## Credentials for the Redfish API.
username = "@{telegraf:ipmi_username}"
password = "@{telegraf:ipmi_password}"
## System Id to collect data for in Redfish APIs.
computer_system_id="1"
## Metrics to collect
## The metric collects to gather. Choose from "power" and "thermal".
include_metrics = ["power", "thermal"]
## Tag sets allow you to include redfish OData link parent data
## For Example.
## Thermal data is an OData link with parent Chassis which has a link of Location.
## For more info see the Redfish Resource and Schema Guide at DMTFs website.
## Available sets are: "chassis.location" and "chassis"
# include_tag_sets = ["chassis.location"]
## Amount of time allowed to complete the HTTP request
# timeout = "5s"
## Optional TLS Config
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
#insecure_skip_verify = false
Does secrets have requirements regarding secret’s content (I mean character encoding) ?
Do you have this issue too ?
I did not found any info regarding secrets support for Redfish ![]()
Regards,
Nikos
