InfluxDBv2 authorization fails if docker secrets are used
Hi folks,
as soon as I switch to docker secrets (file), telegraf authorization to influx fails. If I hardcode the token into the config file, it works.
Bind-mount of docker secret is (IMO) correct:
alexander@ubuntu:~/home-automation$ docker exec -it telegraf sh
# telegraf --version
Telegraf 1.29.2 (git: HEAD@d92d7073)
# cat /run/secrets/telegraf_influxdb_token
jCSA****Ong==
Relevant parts of telegraf config:
# Secret-store to access Docker Secrets
[[secretstores.docker]]
  ## Unique identifier for the secretstore.
  ## This id can later be used in plugins to reference the secrets
  ## in this secret-store via @{<id>:<secret_key>} (mandatory)
  id = "docker_secretstore"
and
# Configuration for sending metrics to InfluxDB 2.0
[[outputs.influxdb_v2]]
  urls = ["http://influx.zimmermann.XXX:8086"]
  token = "@{docker_secretstore:telegraf_influxdb_token}"
  #token = "jCSA****Ong=="
  organization = "zimmermann.XXX"
  bucket = "telegraf/autogen"
Any idea?
This generally means one of few things:
  1. Something is misconfigured
  2. The secret store is not actually readable by the user running telegraf
  3. The password is wrong/has special characters in that are not escaped
Based on what you copied and pasted the config looks fine, so no typo.
What user is running telegraf? Is this as a service?
alexander@ubuntu:~$ docker exec -it telegraf bash
root@telegraf:/# ps auxx
USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
telegraf       1  0.2  0.7 5647052 133932 ?      SLsl Jan15   4:06 telegraf --config=/etc/telegraf/telegraf.conf --config-directory=/etc/telegraf/telegraf.d
root          25  0.1  0.0   4608  3564 pts/0    Ss   22:22   0:00 bash
root          31  0.0  0.0   8480  4220 pts/0    R+   22:22   0:00 ps auxx
root@telegraf:/# ls -la /var/run/secrets/telegraf_influxdb_token
-rw-rw-r-- 1 1000 1000 89 Jan 14 12:22 /var/run/secrets/telegraf_influxdb_token
root@telegraf:/#
Hmm, telegraf user should have access, but …
root@telegraf:~# su telegraf -c cat /var/run/secrets/telegraf_influxdb_token
root@telegraf:~#
I don’t get it :frowning:
What are the permissions on the folder above?
alexander@ubuntu:~/home-automation**$ docker exec -it telegraf bash
total 12
drwxr-xr-x 2 root root 4096 Jan 15 16:52 .
drwxr-xr-x 1 root root 4096 Jan 15 16:52 ..
-rw-rw-r-- 1 1000 1000 89 Jan 14 12:22 telegraf_influxdb_token
total 16
drwxrwxrwt 2 root root 4096 Jan 10 01:00 lock
drwxr-xr-x 2 root root 4096 Jan 15 16:52 secrets
total 44
drwxr-xr-x 1 root root 4096 Jan 10 01:00 .
drwxr-xr-x 2 root root 4096 Dec 9 22:08 backups
drwxr-xr-x 1 root root 4096 Jan 10 01:00 cache
drwxr-xr-x 1 root root 4096 Jan 11 16:26 lib
drwxrwsr-x 2 root staff 4096 Dec 9 22:08 local
lrwxrwxrwx 1 root root 9 Jan 10 01:00 lock -> /run/lock
drwxr-xr-x 1 root root 4096 Jan 11 16:26 log
drwxrwsr-x 2 root mail 4096 Jan 10 01:00 mail
drwxr-xr-x 2 root root 4096 Jan 10 01:00 opt
lrwxrwxrwx 1 root root 4 Jan 10 01:00 run -> /run
drwxr-xr-x 2 root root 4096 Jan 10 01:00 spool
drwxrwxrwt 2 root root 4096 Dec 9 22:08 tmp
I changed /etc/passwd for telegraf user from /bin/false to /bin/bash/ as login shell and run:
root@telegraf:/run/secrets# su telegraf
telegraf@telegraf:/run/secrets$ cat telegraf_influxdb_token
jCSAWc***
Access should not be a problem, IMO. Let me double check the token a third time…
I found the problem, it’s the token itself.
Provide token via environment:
docker compose file:
secrets:
  telegraf_influxdb_token:
    environment: "TELEGRAF_TOKEN"
results in:
alexander@ubuntu:~/home-automation$ docker exec -it telegraf cat /run/secrets/telegraf_influxdb_token
jCSAWc***Ong==alexander@ubuntu:~/home-automation$
Provide token via file:
secrets:
    file: ./.secrets/telegraf_influxdb_token
results in:
jCSAWc***Ong==
The new line at the end is the problem. However my PWD file doesn’t contain any new line:
alexander@ubuntu:~/home-automation$ cat -A .secrets/telegraf_influxdb_token
jCSAW***Ong==$
I believe that is a bug in how telegraf reads the file. Google a bit, I found “Trim contents of slack api urls from files by srhb · Pull Request #2929 · prometheus/alertmanager · GitHub”
Different SW, different use case, but same problem.
Any thoughts?
I’m not following. You said the newline is the problem, but that the file does not have a newline :smiley:
Instead of cat -A $file, can you show the output of od -x $file
How is your file different than our test cases:
@alexander-zimmermann you show above that with
secrets:
there is a newline in the container’s secret, while there is none with the environment-variable setup.
Telegraf can only read the secret-file and use as-is! We should not mess with the content of the secret and we don’t. So if there is a newline at the end of the secret-file you will get a Telegraf secret with a newline at the end!
If your ./.secrets/telegraf_influxdb_token file does not contain a trailing newline, this clearly is an issue with docker or your configuration and should be fixed there.
Did you, by chance, echo the token into the file on your host? If so, did you use -n?
alexander@ubuntu:~$ od -x home-automation/.secrets/telegraf_influxdb_token
0000000 436a 4153 6357 3455 6b62 4878 705f 6954
0000120 756c 4f74 676e 3d3d 000a
0000131
alexander@ubuntu:~$ docker exec -it telegraf od -x /var/run/secrets/telegraf_influxdb_token
0000130
alexander@ubuntu:~/home-automation$ docker exec -it telegraf od -x /var/run/secrets/telegraf_influxdb_token
0000131
First run is the host, second run is the secret mapping via environment, third one via file.
@srebhan Did you agree that docker has no bug since it maps exactly the file from the host?
@srebhan not sure if I understand you correctly. Do you mean the token generation in general?
I generated the token at influx, copy it to clipboard, open vim and paste it, for both the token file ~/home-automation/.secrets/telegraf_influxdb_token and the environment variable in ~/home-automation/.env
Did you notice the 0a at the end of the data when not mapped via environment? Guess what that is! :stuck_out_tongue_winking_eye:
I’m pretty sure that vim will add a newline to a text-file… linux - Why is Vim adding a newline? Is this a convention? - Super User
That’s correct. I also found it out in the meantime.
However, see here: Why Should Text Files End With a Newline in Linux, Section 3.
" POSIX defines a line as a possibly empty sequence of non-newline characters, terminating in a newline, also called EOL (End-Of-Line), ASCII code 0x0A. Meanwhile, a text file is defined as consisting of lines.
Thus, the last line of a file, by definition and standard, should conclude that file with EOL."
I also checked the POSIX standard by myself now. It’s correct, a POSIX conform file must be terminated with a newline.
Sure, I can now tweak my file to be none POSIX conform, but I would be much better to change the telegraf code.
Agree?
Then how do we know it is a text file? What if someone passes a binary AES key in there? Should we just remove random parts of that file?
Please check Manage sensitive data with Docker secrets | Docker Docs. To cite:
  • Generic strings or binary content (up to 500 kb in size)
@srebhan All good questions and I don’t have a finale answer on that. Let’s do the following (suggestion): we enhance the documentation on GitHub and on the webpage and clearly state that telegraf handle/interprate all docker secrets as a binary file even if the file on the host was txt file. So the user should take care that file should not contain a \n at the end.
BTW: why we don’t have an issue w/ influx itself? All tokens work fine. All my tokens have a \n. What is the difference?
Regarding docs, I agree. This looks like a common and easy mistake. I see many similar reports across projects.
Please submit an issue or PR to GitHub - influxdata/docs-v2: InfluxData Documentation that covers InfluxDB Cloud, InfluxDB OSS 2.x, InfluxDB OSS 1.x, InfluxDB Enterprise, Telegraf, Chronograf, Kapacitor, and Flux. and I’ll be happy to review or work on it for docs.influxdata.com and Telegraf repo docs.
Where? For example, in a .env file, variables are key-value pairs; = and the line terminating character are used as delimiters for the value. The token doesn’t contain a new-line character.
@alexander-zimmermann and @Jason_Stirnaman even though, this is not a Telegraf specific issue I would appreciate a PR enhancing the documentation to make people aware of this behavior!
