Hi InfluxDB Community,
I’m reaching out for some help or guidance regarding an issue I’m experiencing with the inputs.http plugin in Telegraf.
I’m using multiple input configuration files to collect data from different IPs via Redfish APIs. Here’s a simplified example of my plugin config:
This is my first config file:
[[inputs.http]]
alias = "http-api-redfish_bios4"
urls = ["https://[ip1]/redfish/v1/systems/1/bios/settings", "https://[ip1]/json/overview"]
method = "GET"
username = "********"
password = "********"
data_format = "json"
tags = { http-api-tag = "http-api-redfish_bios4", nename="xyz"}
json_string_fields = ["*"]
insecure_skip_verify = true
interval = "5m"
timeout = "60s"
[[outputs.elasticsearch]]
alias = "http-api-output-redfish_bios4"
tagpass = { http-api-tag = ["http-api-redfish_bios4"]}
urls = ["http://of-opensearch-master:9200"]
index_name = "redfish-%H"
metric_batch_size = 100
This is my Second config file
[[inputs.http]]
alias = "http-api-redfish_bios6"
urls = ["https://[ip2]/redfish/v1/systems/1/bios/settings","https://[ip2]/json/overview"]
method = "GET"
## Credentials for the Redfish API.
tags = { http-api-tag = "http-api-redfish_bios6", nename="abc"}
interval = "5m"
timeout = "60s"
alias = "http-api-output-redfish_bios6"
tagpass = { http-api-tag = ["http-api-redfish_bios6"]}
Occasionally, I encounter the following warning and debug logs
2025-04-14T15:47:29Z D! [inputs.http::http-api-redfish_bios4] Previous collection has not completed; scheduled collection skipped
2025-04-14T15:47:29Z W! [inputs.http::http-api-redfish_bios4] Collection took longer than expected; not complete after interval of 5m
2025-04-14T15:47:29Z D! [inputs.http::http-api-redfish_bios6] Previous collection has not completed; scheduled collection skipped
2025-04-14T15:47:29Z W! [inputs.http::http-api-redfish_bios6] Collection took longer than expected; not complete after interval of 5m
Once the issue come in the first config file. It impacts all the config file and give the same logs for all config files. And all the files stop writing data to Opensearch
When this happens, it appears to block or delay data collection from other IPs as well, and as a result, metrics aren’t being written to Opensearch as expected.
My Questions:
- Is there a way to isolate the inputs so that if one API call takes too long, it doesn’t affect others?
- Would running each input in a separate Telegraf instance or container help fix the issue?
- Are there any known optimizations or recommended best practices to avoid this issue?
- Are there any known limitations with the inputs.http plugin that might be causing this issue, especially when dealing with multiple IPs?
- Does Telegraf supports parallel execution through the use of inputs.http plugins and configurations.
Thanks in Advance.
