Thanks ahead, can someone suggest how to fix this?
- telegraf is adding this port 443 causing an error
This likely means you’ve misconfigured an incorrect IP address in some capacity - you may be specifying http:// when it isn’t necessary, or something to that effect. If you could share more information, your configuration, or where you’re specifying the OTEL address, it may make it easier to provide a more detailed response.
