We got HTTP response status code 400 bad request for “http://:8086/write?db=service_metrics” in Datadog APM for telegraf.
Telegraf agents are sending the data via wavefront proxy. OS version is CentOS Linux release 7.9.2009 (Core). Telegraf version is 1.10.4 and 1.18.0.
Below error is getting on /var/log/messages
E! Error: parsing sample rate, , it must be in format like: @0.1, @0.5, etc. Ignoring sample rate for line: datadog.trace_agent.events.max_eps.sample_rate:1|g|#version:7.44.1
E! Error: splitting '|', Unable to parse metric: datadog.trace_agent.events.max_eps.sample_rate:1|g|#version:7.44.1
/etc/telegraf/telegraf.conf
[global_tags]
datacenter = "XXX"
environment = "XXX"
[agent]
interval = "180s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "30s"
flush_jitter = "5s"
precision = ""
debug = false
quiet = true
logfile = ""
hostname = "XXXXXXX"
omit_hostname = false
# OUTPUT PLUGINS #
[[outputs.wavefront]]
host = "XXXXXX"
port = 2878
metric_separator = "."
source_override = ["Node"]
convert_paths = true
use_regex = false
# PROCESSOR PLUGINS #
[[processors.strings]]
[[processors.strings.replace]]
tag = "Node"
old = "_"
new = "."
# INPUT PLUGINS #
[[inputs.cpu]]
percpu = true
totalcpu = true
collect_cpu_time = false
fielddrop = ["usage_guest*"]
[[inputs.disk]]
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "iso9660", "overlay", "aufs", "squashfs", "rootfs"]
#fielddrop = ["inodes_*"]
[[inputs.diskio]]
fielddrop = ["weighted_*", "iops_*"]
[[inputs.kernel]]
fielddrop = ["boot_time"]
[[inputs.mem]]
# no configuration
[[inputs.processes]]
# no configuration
[[inputs.swap]]
# no configuration
[[inputs.system]]
# no configuration
fielddrop = ["n_*"]
[[inputs.net]]
fielddrop = ["icmp*", "ip_*", "tcp*", "udp*"]
[[inputs.system]]
# no configuration
[[inputs.internal]]
# ## If true, collect telegraf memory stats.
collect_memstats = true
name_prefix = "telegraf."
[[inputs.chrony]]
# ## If false, set the -n ntpq flag. Can reduce metric gather time.
dns_lookup = true
fieldpass = ["last_offset"]
[[inputs.ping]]
urls = ["XXX"]
/etc/telegraf/telegraf.d/telegraf-application-metrics.conf
[[inputs.influxdb_listener]]
service_address = ":8086"
read_timeout = "10s"
write_timeout = "10s"
name_prefix = "application."
[[inputs.statsd]]
protocol = "udp"
max_tcp_connections = 250
tcp_keep_alive = false
service_address = ":8125"
delete_gauges = true
delete_counters = true
delete_sets = true
delete_timings = true
metric_separator = "_"
allowed_pending_messages = 10000
percentile_limit = 1000
/etc/telegraf/telegraf.d/telegraf-system-listener.conf
service_address = ":8087"
Please help us to fix the issue.
