Telegraf Memory Usage
Hi, I want to know how much memory telegraf agents consumes across all hosts. I’m already gathering data from telegraf internal plugin. Yet, none of the go_memstats is not showing the right numbers, they are far different from what windows task manager shows. I have read about go mems yet couldn’t figure it out.
Can we get this information using telegraf internal plugin by adding or extracting metrics or should I monitor telegraf.service (as windows process)?
To get the OS view of how memory is in use by Telegraf I think you will want to use win_perf_counters or procstat.
Thanks for the answer
