I am interested in installing one agent in one server to monitor other servers within the same network. Is there a way? Is there any plugin that can achieve this? When the data is collected, it should have metrics along with the server name it corresponds too.
Are there any ideas, suggestions that you can provide? Thanks
We don’t have support for this yet, but it would be possible to add it to the win_perf_counters plugin since this is something the performance counters api can do. Can you create a new feature request issue on github?
