I have added more than 50 devices in Inputs.SNMP plugin, but there is almost 1-2 hours delay to push the data to InfluxDB. I dont see any issues on the time zone as it was setup accurately.
Could one of you please confirm if I need to modify anything within Telegraf plugin?
Here is my current configuration of Telegraf for Inputs.snmp
Thank you Srebhan for your response. I did executed the telegraf…–test for specific conf file, however the data still shows almost an hour delay in InfluxDB.
Considering 50+ servers in same telegraf plugin, associated with lot of mib files, not sure if this causing an issue in executing all mib files.
I don’t think the amount is an issue as we have people querying hundreds of servers with one instance. Anyhow, are you sure it is a delay or can it be a timezone or clock issue? In InfluxDB the times are stored as UTC. Is the clock of the telegraf machine set correctly?
What do you get if you convert the timestamp from one of your results in the --test output on a website like www.unixtimestamp.com? Does it say a few seconds ago?
Thank you @Hipska for your response, even I am planning to spilt the agents based on the region wise. I will keep you an update once I validate the output. Thanks
