Hello there,
I have been passed a lot of time trying to make the input snmp working.
Curently the only ouput that i can get is this :
my test config is
# Telegraf configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Global tags can be specified here in key="value" format.
[global_tags]
# dc = "us-east-1" # will tag all metrics with dc=us-east-1
# rack = "1a"
longname = "$longname"
ZONE="$ZONE"
computername="$COMPUTERNAME"
bu="$BU"
storenum="$STORENUM"
[agent]
interval = "60s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will cache metric_buffer_limit metrics for each output, and will
## flush this buffer on a successful write.
metric_buffer_limit = 1000
## Flush the buffer whenever full, regardless of flush_interval.
flush_buffer_when_full = true
collection_jitter = "0s"
## Default flushing interval for all outputs. You shouldn't set this below
## interval. Maximum flush_interval will be flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## Logging configuration:
## Run telegraf in debug mode
debug = true
## Run telegraf in quiet mode
quiet = false
## Specify the log file name. The empty string means to log to stdout.
logfile = "C:/systools/Telegraf/logs/telegraf.log"
## Override default hostname, if empty use os.Hostname()
hostname = ""
# OUTPUTS #
# Configuration for influxdb server to send metrics to
[[outputs.influxdb]]
urls = ["http://10.XX.XX.XX:8086"] # required
database = "telegraf_HV" # required
precision = "s"
timeout = "5s"
# INPUTS #
# Windows Performance Counters plugin.
# These are the recommended method of monitoring system metrics on windows,
# as the regular system plugins (inputs.cpu, inputs.mem, etc.) rely on WMI,
# which utilize more system resources.
# See more configuration examples at:
# https://github.com/influxdata/telegraf/tree/master/plugins/inputs/win_perf_counters
[[inputs.snmp]]
agents = [ "127.0.0.1:161" ]
version = 2
community = "public"
name = "system"
[[inputs.snmp.field]]
name = "hostname"
oid = ".1.0.0.1.1"
is_tag = true
name = "uptime"
oid = ".1.0.0.1.2"
name = "loadavg"
oid = ".1.0.0.1.3"
conversion = "float(2)"
[[inputs.snmp.table]]
name = "remote_servers"
inherit_tags = [ "hostname" ]
[[inputs.snmp.table.field]]
name = "server"
oid = ".1.0.0.0.1.1"
is_tag = true
name = "connections"
oid = ".1.0.0.0.1.2"
name = "latency"
oid = ".1.0.0.0.1.3"
conversion = "float"
my tests were run using this command :
.\bin\telegraf.exe --config .\conf\telegraf_test.conf --test
I try to find out in many different post but nothing make it working properly …
Can Anyone help me please ?
EDIT : I run the telegraf as a service on windows 2008 server
