I am using the telegraf to collect the SNMP metrics from netowrk devices, and then write these metric datas into influxdb2.0. Moreover, It is working well with [inputs.snmp.field], and I can see the metrics of fields in influxdb, but I can see nothing from [inputs.snmp.table] in influxdb. I don’t know why, and I am really confused about that. I hope somebody else can help me and point out the problems happened. Thanks in advance.
1)I have installed the net-snmp-utilis
2) I can use snmpwalk to check these oids availible.
-----------------telegraf.conf is shown as follows----------------------------------------------
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## For failed writes, telegraf will cache metric_buffer_limit metrics for each
## output, and will flush this buffer on a successful write. Oldest metrics
## are dropped first when this buffer fills.
## This buffer only fills when writes fail to output plugin(s).
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Logging configuration:
## Run telegraf with debug log messages.
debug = false
## Run telegraf in quiet mode (error log messages only).
quiet = false
## Specify the log file name. The empty string means to log to stderr.
logfile = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:8086
urls = ["http://192.168.26.134:8086"]
## Token for authentication.
token = "$INFLUX_TOKEN"
organization = "influxdb"
bucket = "telegraf"
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = true
## Whether to report total system cpu stats or not
totalcpu = true
## If true, collect raw CPU time metrics.
collect_cpu_time = false
## If true, compute and report the sum of all non-idle CPU states.
report_active = false
[[inputs.disk]]
## By default stats will be gathered for all mount points.
## Set mount_points will restrict the stats to only the specified mount points.
# mount_points = ["/"]
## Ignore mount points by filesystem type.
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "overlay", "aufs", "squashfs"]
[[inputs.diskio]]
[[inputs.mem]]
[[inputs.net]]
[[inputs.processes]]
[[inputs.swap]]
[[inputs.system]]
[[inputs.ping]]
## Hosts to send ping packets to.
urls = ["192.168.1.1","192.168.3.1"]
## Method used for sending pings, can be either "exec" or "native". When set
## to "exec" the systems ping command will be executed. When set to "native"
## the plugin will send pings directly.
## While the default is "exec" for backwards compatibility, new deployments
## are encouraged to use the "native" method for improved compatibility and
## performance.
method = "exec"
## Number of ping packets to send per interval. Corresponds to the "-c"
## option of the ping command.
count = 5
## Time to wait between sending ping packets in seconds. Operates like the
## "-i" option of the ping command.
ping_interval = 1.0
## If set, the time to wait for a ping response in seconds. Operates like
## the "-W" option of the ping command.
timeout = 1.0
## If set, the total ping deadline, in seconds. Operates like the -w option
## of the ping command.
# deadline = 10
## Interface or source address to send ping from. Operates like the -I or -S
# interface = ""
## Percentiles to calculate. This only works with the native method.
# percentiles = [50, 95, 99]
## Specify the ping executable binary.
binary = "ping"
## Arguments for ping command. When arguments is not empty, the command from
## the binary option will be used and other options (ping_interval, timeout,
## etc) will be ignored.
# arguments = ["-c", "3"]
## Use only IPv6 addresses when resolving a hostname.
# ipv6 = false
[[inputs.snmp]]
## Agent addresses to retrieve values from.
## example: agents = ["udp://127.0.0.1:161"]
## agents = ["tcp://127.0.0.1:161"]
agents = ["192.168.3.1"]
## Timeout for each request.
timeout = "100s"
## SNMP version; can be 1, 2, or 3.
version = 2
## SNMP community string.
community = "public"
## Agent host tag
# agent_host_tag = "agent_host"
## Number of retries to attempt.
retries = 3
## The GETBULK max-repetitions parameter.
max_repetitions = 10
## SNMPv3 authentication and encryption options.
## Security Name.
##sec_name = "wqb"
## Authentication protocol; one of "MD5", "SHA", or "".
##auth_protocol = "MD5"
## Authentication password.
##auth_password = "cisco12345"
## Security Level; one of "noAuthNoPriv", "authNoPriv", or "authPriv".
## sec_level = "authNoPriv"
## Context Name.
name = "snmpdv2"
### Protocols "AES192", "AES192", "AES256", and "AES256C" require the underlying net-snmp tools
### to be compiled with --enable-blumenthal-aes (http://www.net-snmp.org/docs/INSTALL.html)
# priv_protocol = ""
## Privacy password used for encrypted messages.
# priv_password = ""
## Add fields and tables defining the variables you wish to collect. This
## example collects the system uptime and interface variables. Reference the
## full plugin documentation for configuration details.
[[inputs.snmp.field]]
oid = "RFC1213-MIB::sysUpTime.0"
name = "v2_uptime"
oid = ".1.3.6.1.4.1.9.9.109.1.1.1.1.6.1"
name = "cpu5second"
oid = "IF-MIB::ifInOctets.1"
name = " Input_Octets"
[[inputs.snmp.table]]
oid = "IF-MIB::ifTable"
name = "interface"
inherit_tags = ["hostname"]
[[inputs.snmp.table.field]]
oid = "IF-MIB::ifDescr"
name = "ifDescr"
is_tag = true
oid = "IF-MIB::ifHCOutOctets"
name = "ifHCOut"
is_tag = true
