So the docker container logs of one of the telegraf input.vsphere containers ; keeps displaying the error in the image below please is there any fix I can apply to this or has anyone encountered this
Many thanks
Telegraf version: 1.29.2
Please any response will be appreciated
Anaisdg
February 12, 2024, 5:09pm
3
Hello @user_007 ,
I apologize for the delay.
Can you please share your telegraf configuration?
It looks related to this though:
opened 07:33AM - 05 Aug 20 UTC
closed 02:46PM - 26 Oct 22 UTC
platform/windows
area/vsphere
Please redirect any questions about Telegraf usage to the InfluxData Commu… nity
site: https://community.influxdata.com
Check the documentation for the related plugin including the troubleshooting
section if available.
### Relevant telegraf.conf:
```toml
[[inputs.vsphere]]
vcenters = [ "https://hostname/sdk" ]
username = ""
password = ""
interval = "60s"
insecure_skip_verify = true
force_discover_on_init = true
# Exclude all historical metrics
datastore_metric_exclude = ["*"]
cluster_metric_exclude = ["*"]
datacenter_metric_exclude = ["*"]
#historical stats
[[inputs.vsphere]]
username = ""
password = ""
interval = "300s"
object_discovery_interval = "600s"
host_metric_exclude = ["*"] # Exclude realtime metrics
vm_metric_exclude = ["*"] # Exclude realtime metrics
use_int_samples = true
### System info:
using Telegraf v1.15.2 on a Windows 2012 R2 x64 OS connecting to a vCenter 6.7 u3 (latest patches, 6.7.0.44000).
vcenter contains a single cluster with 3 hosts on ESXi 6.7 EP 09 (build 13644319).
### Problem:
telegraf started to produce these errors in the telegraf.log upon every interval of the realtime stats collection. I have no idea why this started. I did some troubleshooting and checked my grafana setup and saw the graphs stopped displaying data in graphs that filter on clustername. There was no clustername in my influxdb measurement anymore. When i stopped filtering on clustername, the graph showed data. It seems the clustername stopped being send to output influxdb as a tag at some point.
Other stats seem to still get pushed out to influxdb.
```toml
2020-08-05T07:28:00Z I! [inputs.vsphere] Unable to find metric name for id %d. Skipping!411
I have the same incident, I have telegraf conteiner version 1.26 and vmware 8.0.2
Can you help me?
