Telegraf drop certain tag values with processor plugin
Is there a way to drop certain tag values before they get sent over to the DB?
Example:
I currently have the following tag values in my InfluxDB:
show tag values from CPU with key=“/components/component/properties/property/@name
key value
/components/component/properties/property/@name mem-util-dma-bytes-allocated
/components/component/properties/property/@name mem-util-dma-size
/components/component/properties/property/@name mem-util-dma-utilization
/components/component/properties/property/@name mem-util-kernel-802-1br-allocations
/components/component/properties/property/@name mem-util-kernel-802-1br-allocations-failed
/components/component/properties/property/@name mem-util-kernel-802-1br-bytes-allocated
/components/component/properties/property/@name mem-util-kernel-802-1br-frees
Is there a way to filter out all tag values that match the word “kernel”. I want the output to look like this:
key value
Thanks,
Mo
Hi @mohsin106,
You can use taginclude or tagexclude ,
 [[inputs.cpu]]
  percpu = true
  totalcpu = true
  taginclude = ["cpu"]
# Exclude the "fstype" tag from the measurements for the disk plugin.
[[inputs.disk]]
  tagexclude = ["fstype"]
I think you can use [“ *kernel *”] without the blanks …
The reference please Search for Metric Filtering …Modifiers …
Best regards
@MarcV Thank you for the reference it helped a ton. In my case I had to use the “tagdrop” setting to target tag values that I did not want showing up in my InfluxDB.
@mohsin106 , thanks for the feedback
I am glad I could help ,
have fun
