Telegraf automated installation
there is a way to automate telegraf installation ? Are you provide scripts to deploy telegraf from github ?
regards.
Using chef you can add the repo
    apt_repository 'influxdb' do
      uri "https://repos.influxdata.com/#{node['platform']}"
      distribution node['lsb']['codename']
      components ['stable']
      arch node['architecture']
      key 'https://repos.influxdata.com/influxdb.key'
    end
and install the package
 package 'telelgraf' do
      action :install
      version '1.2.3'
  end
