There is an issue whilst we running the multiple telegraf.conf files in the same system to capture snmp and snmp_trap both data from the remote agents.
Example:
telegraf1.conf, telegraf2.conf and telegraf3.conf… telegraf10.conf. All 10 config files capturing the snmp data from multiple remote agents without any issue.
Additionally there is one more config file(telegraf_snmp_data) to capture only snmp_trap data. If I start run the this file (telegraf --config telegraf_snmp_trap.conf --test) then other 10 config file stopped getting the snmp data from remote agents, however I need to execute below command separately for each file to capture the remote agent snmp data.
telegraf --config telegraf1.conf --input-filter snmp -output-filter influxdb_v2
telegraf --config telegraf2.conf --input-filter snmp -output-filter influxdb_v2
