Telegraf 1.21.0-rc1 Now Available
Telegraf 1.21.0-rc0 is now available and you can find more details in the full changelog. This Release Candidate (RC) is the first step in moving towards a general release of Telegraf 1.21 and gives the community the opportunity to test and verify new features.
Please join us in testing this release and report any bugs or feedback to the issue tracker.
Key Features:
SNMP enhancements
  • The SNMP plugin now relies on the gosnmi library to parse MIB files directly to improve the performance of Telegraf.
  • The plugin no longer requires the installation of snmptranslate
  • Breaking Change: If your MIBs are not stored in the default location then they they will need to be moved or designated in the plugin configuration setting path = ["/usr/share/snmp/mibs"]
MQTT topics as tags, fields, and measurements
  • The MQTT input plugin now extracts MQTT topic into tags, fields, and measurements
Implementation of deprecation warnings
  • If you are currently using a Telegraf plugin or plugin setting that has been deprecated, we have added a warning message noting the version it was deprecated in and the replacement (if applicable).
New Inputs:
New Aggregators:
New Outputs:
Official Builds:
Arch Platform Package SHA256
arm64 Centos telegraf-1.21.0-0.rc0.aarch64.rpm a10386d7121140283b210b2fcc94846cb13d63d625bbb5bcab265657546f45b1
armel Centos telegraf-1.21.0-0.rc0.armel.rpm e7370fb3c6c5a3844cc7fc5dc31e7a10a3b32898f91db30a648c5b071e9dabeb
armv6hl Centos telegraf-1.21.0-0.rc0.armv6hl.rpm 3f1ea3aa8fdbed8ee04cbfc71196e61fc002bfa1c9f03fc79a04fd010fb3283a
i386 Centos telegraf-1.21.0-0.rc0.i386.rpm 87bf6459b5a47d3dfbaa5e90f50bc45468b7dfac5aad9223941e5676cf6a26b1
ppc64le Centos telegraf-1.21.0-0.rc0.ppc64le.rpm 3ae03d4bcdb20ca2298029341bde9b95dd35b158079df239df4ffd06a42ff8af
s390x Centos telegraf-1.21.0-0.rc0.s390x.rpm ac38acd257dd605eddafe2822f27521d16819a556e8a7f37a5faa739b307c8aa
amd64 Centos telegraf-1.21.0-0.rc0.x86_64.rpm 7e28debf3d0ca801bd5c026aad6666d39ac834e3367aa9e253a27bbd89514d22
amd64 Mac OS X telegraf-1.21.0~rc0_darwin_amd64.dmg d7cd80bd3aa0edbb3005a33040046ab6c6370bc7e5504dfb7481bc3083cc6090
amd64 Mac OS X telegraf-1.21.0~rc0_darwin_amd64.tar.gz 6506b84dbac1561e9d83210cb3fa8623acd476fdae4f6d89c813fb1bf31bf64c
amd64 FreeBSD telegraf-1.21.0~rc0_freebsd_amd64.tar.gz 6768d936a59cdb6b60263ccdce52ad9afb4a5559c24fd7d08dc19d54dd14ce40
armv7 FreeBSD telegraf-1.21.0~rc0_freebsd_armv7.tar.gz 04833fbf62e493cffaf71fa1b09864065d9be65bd4e78f7ad649de3c86b95267
i386 FreeBSD telegraf-1.21.0~rc0_freebsd_i386.tar.gz deadc4385d7b9a000915bcd7f56729f78de7f9f7725c58d1edf5f7877a52431e
amd64 Linux telegraf-1.21.0~rc0_linux_amd64.tar.gz b73e2829d4ae60173377c32cbbd69bcf81853089de52fab387dcb17d54490bec
arm64 Linux telegraf-1.21.0~rc0_linux_arm64.tar.gz 0c7b3538ffd5c6f4481745417095c3c5fe5160f85e0d1095e5a606ca7698cd71
armel Linux telegraf-1.21.0~rc0_linux_armel.tar.gz e64f1253a4b97171411820b0f41aa41f9487dfe873034065f839b37a6c5e85e4
armhf Linux telegraf-1.21.0~rc0_linux_armhf.tar.gz 6bcb95bf933dac586bb3211bb1250c667f5cd3dc81686385f0bb3763a9014412
i386 Linux telegraf-1.21.0~rc0_linux_i386.tar.gz bb672c227d3b1f0dd43db3d5e99748801a9cf445d32aa3d40e255eed8f1d6777
mips Linux telegraf-1.21.0~rc0_linux_mips.tar.gz 7461908b3ab64821c9c0e445eb9159f6ffe323036ce2959f2d278b665f462a8d
mipsel Linux telegraf-1.21.0~rc0_linux_mipsel.tar.gz 77fd109e2e2f8cb202f2893d9271bb81734b7905fe5418bb0f5ca9dd6c1d2b5a
ppc64le Linux telegraf-1.21.0~rc0_linux_ppc64le.tar.gz 4120b63c79a9f2965cfbfe8d9ae83389bcb44a9f31a18a9d86784141cf980c06
s390x Linux telegraf-1.21.0~rc0_linux_s390x.tar.gz bcdfa4e15efda5be3cb25d2df474be914620851d38ab0d8d0588377c1ce3ce49
amd64 Linux telegraf-1.21.0~rc0_static_linux_amd64.tar.gz feca60e704da011436313dce09a46bd30f2c821ac386d887e214094f1ea98282
amd64 Windows telegraf-1.21.0~rc0_windows_amd64.zip 9f52ef63efaf271cf9f55215cf0a9a4b190c455c964c511fa5c0f49db370a29c
i386 Windows telegraf-1.21.0~rc0_windows_i386.zip 2b8bb5ba06c71daea5bedb09c35892994fe4e0c81c71e3b38adbb24741f529e7
amd64 Debian telegraf_1.21.0~rc0-1_amd64.deb 588b4f291ed478f38088d98a51998a19e96707813b49f5cc0b2e67941c0f2126
arm64 Debian telegraf_1.21.0~rc0-1_arm64.deb 0cabdad91217331f3d763bee3dbab7e35e3f29a7ec15a95c7ac11e857ccb8124
armel Debian telegraf_1.21.0~rc0-1_armel.deb 7fe9fa8afa4b5096ded9af20ab0324ba3959643adad377507465a7bccb2e78a7
armhf Debian telegraf_1.21.0~rc0-1_armhf.deb b7f1971662f9a3c6844c3375fc9b3fa6905356024c52572c999d9598ba440503
i386 Debian telegraf_1.21.0~rc0-1_i386.deb 08ce705be863004cb7e177cc3eca202c3d93cd098735e52fd15e48c5ec8b2187
mips Debian telegraf_1.21.0~rc0-1_mips.deb 6e8aaadaa98aa15186290c42a6dcbeaab154f6d9c19ecbf8541c9c877ddb71b9
mipsel Debian telegraf_1.21.0~rc0-1_mipsel.deb 518cd4e89b6f106ed2cfe1d1bffbff4bee5d88b0ffb8ef6503201c7c97d1c04e
ppc64el Debian telegraf_1.21.0~rc0-1_ppc64el.deb c985debb6fa8f781b0c2c8c4c78e5ee19a16c527abe3abad8e6c8fa30680d6a9
s390x Debian telegraf_1.21.0~rc0-1_s390x.deb c0a4ab8e10dc439903b7edfaefb4954003388ba9cc50dfafb1b5f899a2c4fa22
Can we change a contributor in the PMU plugin to @KubaTrojan(KubaTrojan (Kuba Trojan) · GitHub). He was the lead developer of this plugin.
Update December 9, 2021
Telegraf 1.21-rc1 is now available.
Find more details in the full changelog.
