Telegraf 1.9.0-rc2 is now available. This Release Candidate (RC) is the first step in moving towards a general release of Telegraf 1.9 and gives the community the opportunity to test and verify new features. While we hope you download and test all the new plugins and bug fixes, RCs are not meant for production workloads. You can expect additional RCs as bugs are found and fixed before the official release of 1.9.0.
Please join us in testing this release and report any bugs or feedback to the issue tracker.
Changes since 1.9.0-rc1
- Fixed missing jenkins plugin.
- #4789: Fix potential missing datastore metrics in vSphere plugin.
Release Notes
The
http_listenerinput plugin has been renamed toinfluxdb_listenerand
use of the original name is deprecated. The new name better describes the
intended use of the plugin as a InfluxDB relay. For general purpose
transfer of metrics in any format via HTTP, it is recommended to use
http_listener_v2instead. -
Input plugins are no longer limited from adding metrics when the output is
writing, and new metrics will move into the metric buffer as needed. This
will provide more robust degradation and recovery when writing to a slow
output at high throughput.To avoid over consumption when reading from queue consumers:
kafka_consumer,
amqp_consumer,mqtt_consumer,nats_consumer, andnsq_consumeruse
the new optionmax_undelivered_messagesto limit the number of outstanding
unwritten metrics.
New Inputs
- http_listener_v2 - Contributed by @jul1u5
- ipvs - Contributed by @amoghe
- jenkins - Contributed by @influxdata & @lpic10
- nginx_plus_api - Contributed by @Bugagazavr
- nginx_vts - Contributed by @monder
- wireless - Contributed by @jamesmaidment
New Outputs
- stackdriver - Contributed by @jamesmaidment
1.9 also contains a long list of additional enhancements. Please reference the full changelog for release notes and the comprehensive list of changes.
Official builds:
- https://dl.influxdata.com/telegraf/releases/telegraf_1.9.0~rc2-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0-0.rc2.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.9.0~rc2-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0-0.rc2.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_windows_i386.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.9.0~rc2-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0-0.rc2.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.9.0~rc2-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.9.0~rc2-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0-0.rc2.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0-0.rc2.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.9.0~rc2-1_s390x.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0-0.rc2.s390x.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.9.0~rc2_linux_s390x.tar.gz
