Telegraf 1.15.0-rc3 Now Available
Telegraf 1.15.0-rc2 is now available and you can find more details in the full changelog. This Release Candidate (RC) is the first step in moving towards a general release of Telegraf 1.15 and gives the community the opportunity to test and verify new features.
Please join us in testing this release and report any bugs or feedback to the issue tracker.
Release Notes
  • The logparser input is deprecated, use the tail input with data_format = "grok" as a replacement.
  • The cisco_telemetry_gnmi input has been renamed to gnmi to better reflect its general support for gNMI devices.
  • Several fields used primarily for debugging have been removed from the splunkmetric serializer, if you are making use of these fields they can be added back with the tag option.
  • Telegraf’s --test mode now runs processors and aggregators before printing metrics.
  • Official packages now built with Go 1.14.4.
  • When updating the Debian package you will no longer be prompted to merge the telegraf.conf file, instead the new version will be installed to /etc/telegraf/telegraf.conf.sample . The tar and zip packages now include the version in the top level directory.
New Inputs
New Processors
New Outputs
Official Builds:
Arch Platform Package SHA256
amd64 Debian telegraf_1.15.0~rc2-1_amd64.deb 79d8b3fb52ab3c58589dc40a7f6eecd6ce207215120b70cc013d1dc154a8923e
arm64 Debian telegraf_1.15.0~rc2-1_arm64.deb 4786f8a8cfe51cb6b7b1c3ba14989aa2d4a5a06c471e5b9c1b34858ba918d1a2
armel Debian telegraf_1.15.0~rc2-1_armel.deb 12982317767383120915e69099a33f5f905272c925539c3a030f4539dc0152fe
armhf Debian telegraf_1.15.0~rc2-1_armhf.deb fc45f3ea76332ffcf0834a3231554efe50cb94290cfbd29e2d1c9c92c25b0273
i386 Debian telegraf_1.15.0~rc2-1_i386.deb 512c9840736c50c4cac967381671546abf32cb4d801e6485c21ee1edc0ca6dc7
mips Debian telegraf_1.15.0~rc2-1_mips.deb 2332b1794c75630c3e6cf751257ba9915401958d3ab1fa1077de4e66d3ec1aaa
mipsel Debian telegraf_1.15.0~rc2-1_mipsel.deb 81b82151750fadf74cfc2121397e7eacff39a1f52d2f8dbd455f3ffbc285fc35
s390x Debian telegraf_1.15.0~rc2-1_s390x.deb 8d3dd002fda99a4d9e0e45d5539e61037d7a9f62179a85be16dbaa08996e1e7a
arm64 Centos telegraf-1.15.0-0.rc2.aarch64.rpm 045f65ebfd93a4d32f0379de152a7204ce10226735060a02ded9874fd63d5d30
armel Centos telegraf-1.15.0-0.rc2.armel.rpm 2b8d8588c4de4ec49e44fad45fea236969b8c81af8e27e601a343e07f021cac7
armv6hl Centos telegraf-1.15.0-0.rc2.armv6hl.rpm 7dd821c69bc8c879fc0e8cbb33f4bb02974f28ded4fb6f6e0f982eb573ca0644
i386 Centos telegraf-1.15.0-0.rc2.i386.rpm c89ddef0ef308b52201fabaa752b17117a0d1de81bfea8893978b9f494f1d30e
s390x Centos telegraf-1.15.0-0.rc2.s390x.rpm cf4be54548732e4abad0f8bffeeb8b69c32e8b9a6e376089134656515b57f16e
amd64 Centos telegraf-1.15.0-0.rc2.x86_64.rpm 204f6c0029e91e8fa9a330c53b4270c0e1465a91183a526635911bccf1c8afc6
amd64 Windows telegraf-1.15.0~rc2_windows_amd64.zip 1e25dba6777a5dc27999be32693219bb59bb043a0d937e001744b7ac0a2e0db5
i386 Windows telegraf-1.15.0~rc2_windows_i386.zip a3b01dbf545cd02dc481e6b9c636beedbebf7b2eb8c9ec3084185ee855132b2a
amd64 Mac OS X telegraf-1.15.0~rc2_darwin_amd64.tar.gz 02d9c2510517e6c51a969990b6ca0c750765890075961fd245afece52379907a
amd64 FreeBSD telegraf-1.15.0~rc2_freebsd_amd64.tar.gz 5681d16011d9b7cadb32864dba870c182b4312c87516e0cbf260bf08a3619335
i386 FreeBSD telegraf-1.15.0~rc2_freebsd_i386.tar.gz 43e4b277b29b9582bd4e76e802907b9745dd499cd016d0b837c6a8c8c5aed6ac
amd64 Linux telegraf-1.15.0~rc2_linux_amd64.tar.gz fb50c57056a99fa5e0031a6dd98d09ab873a3924d3f60d2aa061dfcdff2c3d50
arm64 Linux telegraf-1.15.0~rc2_linux_arm64.tar.gz b2657432e9cbe3eed81aa8f971baf90b95810b58e75095986eea467c703d0ca4
armel Linux telegraf-1.15.0~rc2_linux_armel.tar.gz 349d77264fbf6faeb04aac224f8688c4986a6d2efc21410a668bc5acfa912a7f
armhf Linux telegraf-1.15.0~rc2_linux_armhf.tar.gz 91fe00655ada5fce81d26111c5c751f3ed5a9204259e02af8687aa6c9eb7735c
i386 Linux telegraf-1.15.0~rc2_linux_i386.tar.gz 198c6dbf539c9388f3d8adb82d4ca0735b48518ceb758b458bb9eda3c81f5287
mips Linux telegraf-1.15.0~rc2_linux_mips.tar.gz 4a881b08e3fbae58dba683934c805432f7c55b58015e287ef34566aa5d913425
mipsel Linux telegraf-1.15.0~rc2_linux_mipsel.tar.gz 25c086f08f02f5435245694760164c2201caa8da56b06f883cbb2146be5fadea
s390x Linux telegraf-1.15.0~rc2_linux_s390x.tar.gz 5cf877633abf0ffca2b78f38efeda455eaab84ee2cf0123d7775b42873c2286c
amd64 Linux telegraf-1.15.0~rc2_static_linux_amd64.tar.gz 55c6a490fccc766e6a074b9898924778a62a06de3850cf2d61aff158becfef30
Update July 16, 2020:
Telegraf 1.15.0-rc3 is now available. This Release Candidate (RC) fixes a few bugs found in Telegraf 1.15.0-rc2 including expiring old cached entries in the ifname processor, sending metrics in FIFO order, and updated Go versions. You can find more details in the full changelog.
Update July 20, 2020:
Telegraf 1.15.0-rc4 is now available. This Release Candidate (RC) fixes a few bugs found in Telegraf 1.15.0-rc3 including a bugs to the ifname processor and initialization with processors that are run after aggregators. You can find more details in the full changelog.
