Hello everybody,
I am developing a Go application that sends events (logs) to a Telegraf instance, configured with the network_socket plugin and listening to TCP port 8094.
The application sends logs using the influxdb line protocol (the client was developed by me)
Unfortunately not all my events show up in the influx instance (let’s say 1/4 of total events).
Following the advice of a developer in the influxdb Slack channel I have grabbed some TCP dumps of the entire data flow (app->telegraf and telegraf->influx)
I have checked telegtraf and influx logs and I didn’t find any error.
tcpdump_influx: tcpdump_influx - Pastebin.com
tcpodump_telegraf: tcpdump_telegraf - Pastebin.com
select * from log:
> select * from log name: log time Command command componentName host level message parserName path source version ---- ------- ------- ------------- ---- ----- ------- ---------- ---- ------ ------- 1498997687733343800 SetCodeStatus SetCodeStatus influxline 4i Registering component ComponentResolver SingleCode commands - 1.0.0-alfa - SingleCode commands component 1498997687733842900 GetBookedItems GetConfiguration GetConfiguration influxline 4i Registering component GetBookedItems ComponentResolver Node commands - 1.0.0-alfa - Node commands management components 1498997687734350700 AppendItems SetLocalTime SetLocalTime influxline 4i Registering component SetItems ComponentResolver Node commands - 1.0.0-alfa - Node commands management components 1498997687735846100 AGEXIO SetNtin SetNtin influxline 4i Startup AGEXIO ETS Node commands - 1.0.0-alfa - Node commands management components 1498997688739575400 influxline 4i Registered block dispatch paths /SetItems/*/SetItems engine.Line 1498997792084983300 SetCodeStatus SetCodeStatus influxline 4i Registering component ComponentResolver SingleCode commands - 1.0.0-alfa - SingleCode commands component 1498997792085978300 AppendItems SetLocalTime SetLocalTime influxline 4i Registering component SetItems ComponentResolver Node commands - 1.0.0-alfa - Node commands management components 1498997792088480100 AGEXIO SetNtin SetNtin influxline 4i Startup AGEXIO ETS Node commands - 1.0.0-alfa - Node commands management components 1498997793090443800 influxline 4i Registered block dispatch paths /Legacy/*/Legacy engine.Line
What could I be missing?
Thank you
