Found a solution which might look a bit messy, but it works. Here’s the TICK script.
It might still need some optimizations, so in case you have any ideas, please help out.
Thanks!
var liquid = batch
|query('SELECT * FROM "redacted"."a_month"."vwap_1m"')
.align()
.period(2m)
.every(1m)
|httpOut('liquid0')
|eval(lambda: "base", lambda: "priceVWAP", lambda: string("quote") + 'USD', lambda: "24h_volume", lambda: if("quote" == 'USD', 100000000000000000.0, float("24h_volume")))
.as('base', 'priceVWAP', 'bq', '24h_volume_orig', '24h_volume')
.tags('base', 'bq')
.keep('quote', 'priceVWAP', '24h_volume_orig', '24h_volume', 'bq')
|groupBy('base')
var liquidSum = liquid
|sum('24h_volume_orig')
.as('sum_24h_volume')
liquid
|max('24h_volume')
.as('24h_volume')
|httpOut('liquid')
|influxDBOut()
.database('redacted')
.retentionPolicy('a_month')
.measurement('vwap_1m_ext')
var usd = batch
.align()
.period(2m)
.every(1m)
|where(lambda: "quote" == 'USD')
|httpOut('usd')
|eval(lambda: string("base") + string("quote"))
.as('bq')
.tags('bq')
.keep('priceVWAP')
|groupBy('bq')
|last('priceVWAP')
.as('priceC')
var liquid_ext = batch
|query('SELECT * FROM "redacted"."a_month"."vwap_1m_ext"')
.align()
.period(2m)
.every(1m)
.groupBy('bq', 'base')
|max('priceVWAP')
.as('priceC')
|join(usd)
.as('liquid_ext', 'usd')
.on('bq')
.tolerance(1m)
|eval(lambda: "base", lambda: "liquid_ext.24h_volume", lambda: "liquid_ext.priceC", lambda: "liquid_ext.quote", lambda: if("quote" == 'USD', "liquid_ext.priceC", "liquid_ext.priceC" * "usd.priceC"))
.as('base', '24h_volume', 'price_init', 'quote', 'price')
|influxDBOut()
.measurement('vwap_1m_ext_converted')
var liquid_ext_converted = batch
|query('SELECT "base", "price", "24h_volume" FROM "redacted"."a_month"."vwap_1m_ext_converted"')
.align()
.period(2m)
.every(1m)
.groupBy('base')
|max('24h_volume')
.as('24h_volume')
|join(liquidSum)
.as('l1', 'l2')
.tolerance(1m)
|eval(lambda: "l1.base", lambda: "l1.price", lambda: "l2.sum_24h_volume", lambda: "l2.sum_24h_volume" * "l1.price")
.as('base', 'price', '24h_volume', '24h_volume_usd')
|httpOut('liquid_final')
|influxDBOut()
.measurement('vwap_1m_usd')
