I have a script like following
batch
|query('SELECT sum("value") FROM "app"."autogen"."measurement" WHERE ' +
'product = \'' + product + '\'')
.every(1m)
.offset(5m)
.period(1m)
.groupBy('event_type')
.align()
.fill('none')
|alert()
.warn(lambda: 0 < 1)
.message(message + ' {{.Group}}')
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.log('/var/lib/kapacitor/logs/alerts.log')
It calls alert node for every unique event_type as given in documentation. But I want to combine it somehow. for me event_type has types like 404, 400, 401, total_request etc (these are variable) and i want to find percentage of 404, 400, 401 and then say
if percentage(404) > x and percentage(400) < y and percentage(401) > 0 then push something to influxdb different measure. (percentage(x) = sum(x)/total_requests*100)
And in order to do this i need to have access to all those sum('value') of all event_types in the same node at same time so that can use it in my usecase. One way i found was to get all data without groupBy and then find different sums on kapacitor side. but it ends up retrieving 100k+ values which is waste.
So what would be other way of doing it ?
Thanks !
