Hi!
While my problem seems very trivial to solve, I still struggle coming up with a solution.
I have a stream of data at a db called “products” with “autogen” retention policy (it has 2d lifespan and is gathering data every 10s).
I also have a downsampled data inside the same “products” db with “rp_1h_window” retention policy.
The field I’m interested in is called “price”.
I want to write a TICK script that will notify me whenever “products”.“autogen” gets a new “price” with a value lower than minimal “price” of the previous week in “products”.“rp_1h_window”.
I suppose I should use a batch script for that?
I tried the following, but it does not work for some reason:
dbrp "products"."autogen"
dbrp "products"."rp_1h_window"
var minPriceLast7d = batch
|query('''
SELECT min("price")
FROM "products"."rp_1h_window"."my_metric_name"
.period(7d)
.every(1m)
|log()
var minPriceLastMinute = batch
|query('''
SELECT min("price")
FROM "products"."autogen"."my_metric_name"
.period(1m)
.every(1m)
|log()
var data = minPriceLast7d
|join(minPriceLastMinute)
.as('minPriceLast7d', 'minPriceLastMinute')
|log()
|alert()
.crit(lambda: "minPriceLastMinute.min" < "minPriceLast7d.min")
.message('The price is lower!')
.telegram()
The names are correct. The .telegram() is working fine, I’ve tested it separately.
here’s the script’s graph:
graph [throughput="0.00 batches/s"];
query3 [avg_exec_time_ns="687.020305ms" batches_queried="15" errors="0" points_queried="15" working_cardinality="0" ];
query3 -> log4 [processed="15"];
log4 [avg_exec_time_ns="4.164149ms" errors="0" working_cardinality="0" ];
log4 -> join6 [processed="15"];
query1 [avg_exec_time_ns="498.765513ms" batches_queried="15" errors="0" points_queried="15" working_cardinality="0" ];
query1 -> log2 [processed="15"];
log2 [avg_exec_time_ns="1.888199ms" errors="0" working_cardinality="0" ];
log2 -> join6 [processed="15"];
join6 [avg_exec_time_ns="965.726µs" errors="0" working_cardinality="1" ];
join6 -> log7 [processed="28"];
log7 [avg_exec_time_ns="44.945µs" errors="0" working_cardinality="0" ];
log7 -> alert8 [processed="28"];
alert8 [alerts_inhibited="0" alerts_triggered="0" avg_exec_time_ns="3.280364ms" crits_triggered="0" errors="0" infos_triggered="0" oks_triggered="0" warns_triggered="0" working_cardinality="1" ]
What I may be doing wrong and how should I write the script?
