I’m having an issue polling a device with the problem that noting is getting written to the /tmp/snmp-microsemi.txt file.
telegraf agent version 1.27.2
telegraf config:
[agent]
interval = "20s"
round_interval = true
metric_batch_size = 10000
metric_buffer_limit = 10000
flush_interval = "20s"
flush_jitter = "0s"
debug = true
logfile = "/tmp/telegraf.log"
omit_hostname = false
[[inputs.snmp]]
agents = ["udp://192.168.103.232:161"]
timeout = "10s"
community = "microcommr"
version = 2
[[inputs.snmp.field]]
oid = "RFC1213-MIB::sysName.0"
name = "sysName"
is_tag = true
name = "ntpSysLeap"
oid = "S650::ntpSysLeap"
[[outputs.file]]
files = ["/tmp/snmp-microsemi.txt"]
I can do an snmp walk and get the desired result verifying they mib is loaded:
snmpwalk -v 2c -c microcommr 192.168.103.232 S650::ntpSysLeap
S650::ntpSysLeap.0 = INTEGER: noWarning(0)
snmpwalk -v 2c -c microcommr 192.168.103.232 RFC1213-MIB::sysName
SNMPv2-MIB::sysName.0 = STRING: SyncServer
snmpwalk -v 2c -c microcommr 192.168.103.232 .1.3.6.1.4.1.9070.1.2.5.7.8.1.2
S650::ntpSysStratum.0 = INTEGER: 2
He debug file does not show any issues
[agent] Initializing plugins
[inputs.snmp] executing "snmptranslate" "-Td" "-Ob" "RFC1213-MIB::sysName.0"
[inputs.snmp] executing "snmptranslate" "-Td" "-Ob" "S650::ntpSysLeap"
[agent] Connecting outputs
[agent] Attempting connection to [outputs.file]
[agent] Successfully connected to outputs.file
[agent] Starting service inputs
[outputs.file] Buffer fullness: 0 / 10000 metrics
If I add the following using the enterprise oids then I get some data, but not from the manufacturer’s MIB.
name = "hostname"
oid = "1.3.6.1.2.1.1.5.0"
is_tag = true
name = "uptime"
oid = "1.3.6.1.2.1.1.3.0"
text file:
snmp,agent_host=192.168.103.232,host=influxdb,hostname=SyncServer,sysName=SyncServer uptime=50832000i 1733764465000000000
snmp,agent_host=192.168.103.232,host=influxdb,hostname=SyncServer,sysName=SyncServer uptime=50832500i 1733764470000000000
I have seen post but not may solutions on this. Anyway to debug this process any better then just the debug option?
