Hi all,
I want to collect some integer data with Telegraf snmp plugin and when I’m using only inputs.snmp.field, is working. But when I want to save these metrics to separated measurement with inputs.snmp.table and inputs.snmp.table.field, Telegraf is not executing these inputs (checked with “telegraf --config /etc/telegraf/telegraf.conf --test --debug”).
snmpwalk -v 2c -c test 10.67.221.133 1.3.6.1.4.1.9148.3.2.1.1.2.0
SNMPv2-SMI::enterprises.9148.3.2.1.1.2.0 = INTEGER: 37
Working Configuration:
[[inputs.snmp]]
agents = [ "10.67.221.133:161" ]
timeout = "5s"
retries = 3
version = 2
community = "test"
[[inputs.snmp.field]]
name = "apSysMemoryUtil"
oid = "1.3.6.1.4.1.9148.3.2.1.1.2.0"
Not Working Configuration:
[[inputs.snmp]]
timeout = "5s"
retries = 3
version = 2
community = "test"
[[inputs.snmp.table]]
name = "tasbc"
[[inputs.snmp.table.field]]
When I try to collect string data, then the inputs.snmp.table and inputs.snmp.table.field configuration is working:
snmpwalk -v 2c -c test 10.67.221.133 1.3.6.1.2.1.1.5
SNMPv2-MIB::sysName.0 = STRING: tasbc01
[[inputs.snmp]]
timeout = "5s"
retries = 3
version = 2
community = "test"
name = "tasbc"
name = "Hostname"
oid = "1.3.6.1.2.1.1.5"
Does anybody know if metric data type can influence if Telegraf will execute such snmp inputs ?
