Hi ,
I want to know if can i send alert notification by SMS
Hi Nadia,
I think you can find that information in the Grafana documentation here. If you’re using InfluxDB with Grafana, alerting is definitely supported.
Best of luck!
yes I already read that but I did not find that we can send notification by SMS to the phone
did you find any solution to send alert as an SMS ?
My reply might be a bit late, but you might want to check out our app-based alerting service SIGNL4 that supports app push, SMS text and voice calls including escalations, duty scheduling and collaboration.
You can find a detailed description on how to integrate SIGNL4 with InfluxDB here:
