Hello @Ashish_Sikarwar,
I’m not sure I completely understand what it is that you’re trying to achieve. Can you please break it down for me a little bit more?
Sideload is similar to csv.from() in Flux though.
Our requirement was to create 1 alert per test which can also handle different condition/threshold for different host.
Example:
Assuming we have an Alert for CPU Consumption by .exe or Processes like python.exe chrome.exe etc
Client/Host A does not to alert on Chrome
Client/Host B wants to alert on Chrome but not on python
Now I was able to make use of the following document and created host based thresholds.
Next Level: Where we can either use the same sideload or flux csv feature to create much more complex condition as mentioned above.
How do you mean? You can use csv.from() within your task and then use the information in the csv to craft your task for alerting.
