I’m looking into the sideload feature of tickscript, may be someone has experience here?
I want to alert on disk usage with different thresholds per host/path.
The script looks like:
var data = stream
|from()
.measurement('disk')
.groupBy(['path', 'host'])
.where(whereFilter)
|eval(lambda: "used_percent")
.as('value')
var trigger = data
|sideload()
.source('file:/etc/kapacitor/sideload')
.order('{{.host}}.yml')
.field('disk_used_info', 70.0)
.field('disk_used_warn', 85.0)
.field('disk_used_crit', 95.0)
|alert()
.message(message)
.info(lambda: "value" > "disk_used_info")
.warn(lambda: "value" > "disk_used_warn")
.crit(lambda: "value" > "disk_used_crit")
.stateChangesOnly(1h)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
Now the issue is, I can define thresholds per host, but I cannot figure out how to store thresholds per path.
It would be logical to have an include like
.order('{{.host}}/{{path}}.yml')
but as “path” contains slashes this won’t work.
It would also be nice to have nested structs inside the yml files like
/var:
warn: 80
crit: 90
but it looks like the files need to be flat.
