Hi there,
I’m new to the TICK-Stack, evaluating the possibilities for our project. Right now I have a problem with the Kapacitor/tickScript. I need to load additional parameters into my alerts so i am using sideloads. The problem is, that my setup is very large, about 40.000 objects. So creating a sideload-file for every object would be a massive impact on inodes. I would like to group the object into bundles (host-file with infos for hosts and the hosts services). But i am stuck on a few attempts i have tried so far:
Imagine this tickScript:
dbrp "telegraf"."autogen"
stream
|from()
.measurement('nagios_state_check_icmp')
.where(lambda: "host" == '1234')
|sideload()
.source('file:///scripts/sideload')
.order('{{.host}}.yml')
.tag('maintenance', 'FALSE')
|alert()
.crit(lambda: int("state") > 0 AND "maintenance" == 'FALSE')
.log('/tmp/alerts.log')
Should be straight forward. Working for the host itself. But how to use this as a default script for all hosts and services?
1. nested yaml?
My first attempt was to create a nested yaml:
1234.yml
maintenance: false
services:
5678:
maintenance: true
9012:
maintenance: false
But i wasn’t able to parse it to get the nested value services->5678->maintenance.
Does the sideload support nested yaml? There are no examples in the documentation and it is not written anywhere (at least I couldn’t find it)
2. prefixed keys
Second approach was to use prefixed keys:
1234.yml
maintenance: false
5678_maintenance: true
9012_maintenance: false
But again, the .field() and .tag() methods of the sideload don’t seem to support templating to dynamically create the string from data-set parameters
.tag( '{{.service}}_maintenance' , 'FALSE')
So is the only possibility to create 40.000+ files or is there a trick I don’t know yet?
