Shot in the dark but I wonder if anyone can help.
I’m trying to figure out how to send json data from Google Scripts to Influx and am using the following code:
function testPost() {
var response;
var tags = {
testname:‘j’
var fields = {
value:1
var data = {‘measurement’:‘cpu_load_short’,‘tags’:tags,‘time’:0,‘fields’:fields};
Logger.log(JSON.stringify(data));
var options = {
‘method’ : ‘post’,
‘muteHttpExceptions’ : true,
‘contentType’: ‘application/json’,
‘payload’ : JSON.stringify(data)
options = {
‘method’ : ‘post’,
‘contentType’: ‘text/plain’,
‘payload’ : ‘mymeas,mytag=blob myfield=90 1463683075000000000’
try {
response = UrlFetchApp.fetch('http://w.x.y.z:8086/write?db=mydb&u=***&p=***', options);
Logger.log(response.getContentText());
catch(err) {
Logger.log(err);
This is what I capture from the google script:
[19-09-05 13:52:39:586 BST] {“measurement”:“cpu_load_short”,“tags”:{“testname”:“j”},“time”:0,“fields”:{“value”:1}}
[19-09-05 13:52:39:698 BST] {“error”:“unable to parse ‘{“measurement”:“cpu_load_short”,“tags”:{“testname”:“j”},“time”:0,“fields”:{“value”:1}}’: missing tag value”}
I suspect the issue is somewhere with the JSON.stringify but not entirely sure why. The error seems to indicate missing tag data despite it being provided.
