Luv
May 3, 2017, 11:49am
1
How can I send data from telegraf on my system to influxdb on another system ?
I know I have to give telegraf the address of influxdb ,
[outputs.influxdb]
urls = ["http://localhost:8086"]
But influxdb is running on the local port on another system. We have to make it publically accessible. How can we do that ?
I did this in my influxdb.conf file,
[http]
bind-address = "0.0.0.0:8086"
But that did not wwork.
@Luv is the port 8086 open on your InfluxDB instance? Assuming that it is
[outputs.influxdb]
urls = ["http://<your instances IP>:8086"]
should work.
Luv
May 3, 2017, 9:00pm
3
@michael
abc@xyz:~$ sudo netstat -ntlp | grep influx
tcp6 0 0 :::8086 :::* LISTEN 5473/influxd
tcp6 0 0 :::8088 :::* LISTEN 5473/influxd
It is running on my instance.
The IP which I use to connect to my server is 35.185.176.233.
So, when I write something like this,
[[outputs.influxdb]]
urls = ["http://35.185.176.233:8086"] # required
database = "telegraf" # required
The logs says,
2017-05-03T20:55:02Z E! Database creation failed: Post http://35.185.176.233:8086/query?db=&q=CREATE+DATABASE+%22telegraf%22: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
Why is this happening ?
Can you refer me some kind of docs for my scenario ?
Luv
May 4, 2017, 7:51am
4
Yeah I got it.
There were some issues with Firewall. I changed them after wasting a lot of time, and is now working.
