Hi, I’m trying to understand if this is even something that is supported? Or if i’m missing something.
I am running telegraf and i want to store the metrics on a remote server.
I have tried both the http and udp endpoints, there is no issue with the connection between the servers, and the influxdb:1.0 docker image has the ports bound:
0.0.0.0:8083->8083/tcp, 0.0.0.0:8086->8086/tcp, 0.0.0.0:21337->21337/udp
The influx conf:
[[udp]]
enabled = true
bind-address = ":21337"
database = "udp"
retention-policy = ""
batch-size = 5000
batch-pending = 10
read-buffer = 0
batch-timeout = "1s"
precision = ""
Telegraf conf :
[[outputs.influxdb]]
urls = ["udp://ip:21337"] # required
database = "test" # required
retention_policy = ""
write_consistency = "any"
timeout = "5s"
I can see the data coming in if i run nc -ul 21337 on the influx db server but it’s just not populating the db?
