Error while sending data from Telegraf to Influxdb-relay
Hello, I am trying to send the data from Telegraf to Influxdb-relay and from there to Influxdb i.e., Telegraf → Influxdb_relay → Influxdb. So, I have configured Influxdb-relay IP in the telegraf.conf
as follows:-
[[outputs.influxdb]]
urls = [“http://172.29.29.12:9096/write”]
But the issue is Telegraf is not able to write to Influxdb-relay I am getting error as “Database creation Failed: post http://172.29.29.12:9096/query?q=CREATE DATABASE getsockopt: connection refused
Can anyone know the solution for this. Can anyone please suggest the correct way to allow Telegraf send data to Influxdb-relay.
Any help is much appreciated. Thank you
Is the port open on 9096 ?
