Hi there!
I’ve downloaded the project GitHub - influxdata/chronograf: Open source monitoring and visualization UI for the TICK stack , and now trying to run it by make command. It’s running without any problems but I can’t reach it via browser. How can I run it to get chonograf ui via browser
Thanks in advance!
The “make” command only builds Chronograf, it does not install or run it.
Unless there is a specific reason you are trying to build from source, we recommend installing Chronograf using our pre-built packages. You can find instructions for your operating system in the Chronograf Installation Documentation.
