I have a influxdb server collecting sensor data which i visualize in Grafana , but i also want to do some calculations on the data and need to get it into Google Sheets. I would imagine that getting a Json or CSV response into google sheets is not impossible ( i just dont know where to start properly ). Is there anyone that has a practical example that they can share with me or help me further?
Any help in this forum?
Seems this is more of a google sheets question than an influx question. How are you trying to export the data currently?
CSV would be the easiest route, Google Sheets knows how to import that natively.
This post shows an example using the influx command against an InfluxDB 1.x database: Export daily data to csv - #4 by lgosselin
