I have a question regarding querying an InfluxDB Cloud instance using Google Sheets (via an HTTP Query) I am working on for a proof of concept. In a Google Sheets API Script I am using the FETCH command to effectively run the command below. “MY” Tags used to substitute for actual values.
I have also pasted this same query into a browser window with the same result. The output is shown below.
{“results”:[{“statement_id”:0,“error”:“database not found: MYBUCKETNAME”}]}
Can anyone help with the error I am receiving? I have begun to look into DB mapping via the CLI but fail to understand how this accomplished when using a Cloud Instance. Any help is appreciated.
