asif
1
Hi Guys,
I have started learning influxdb two months ago. I have stored data of a sensor into it.
Now i want to make the data analysis. Please suggest me an easy way to get the data into a file.
Thank you.
@asif Hi !
You can build your query in Chronograf and click on the CSV download button on the right corner.
Be careful, it downloads the data for the selected time range.
I hope it will help you.
Nicolas
But if you want to do analysis, you can directly do it in Chronograf.
asif
3
Thank you very much for your time.
sorry, i am using influxdb in a terminal on window. Where and how can i get this graphic view??
You have to install Chronograf according to this doc Installing Chronograf | Chronograf 1.7 Documentation.
But I think it’s only on Linux, Mac, or in Windows with docker Docker.
If you don’t want to install Chronograf and download data, you can do this with a curl command like suggested in this post Export big data from influxdb - #2 by sbains
asif
5
Thank you NicolasDrapier.
I think we can install it only on Linux.
Is it possible to install on window 10. If yes, please i Need Little Explanation.
Thank you once again.
You can install it with docker.
