Reading CSV Files into Influxdb that are stored on a FTP Server
Hi all,
I am trying to read CSV files on a FTP server (protected with username and password) into Influxdb. These files are produced constantly. I have 1 file for each day plus a the csv file for today, which is filled with data up to now.
Please see below the structure of the csv files:
(s) Date Time Lue01.An.ABL_T.Istwert Lue01.An.ABL_rF.Istwert Lue01.An.ABL_aF.Istwert Lue01.An.ABL_Tp.Istwert
1672876809 05.01.2023 00:00:09 29.8 52.8 14.8 19.5
1672876819 05.01.2023 00:00:19 29.7 52.8 14.8 19.4
1672876829 05.01.2023 00:00:29 29.7 52.9 14.8 19.4
1672928879 05.01.2023 14:27:59 29.7 48 13.4 17.7
1672928889 05.01.2023 14:28:09 29.7 47.9 13.3 17.7
The URL of the files looks like this:
http://192.168.X.X/M2_FLASH/WEBPAGES/DATA/LUE01_ABL_D230105.CSV
Is there a way to capture this data in indluxdb?
Many thanks in advance!
Hi @Globgogabgalab
Very easy to do with Node-RED. Have you explored that product at all?
Hi @grant1 ,
Thanks for the tip! I am only using the node-red application in my home assistant setup to automate my zigbee lights. Is there a tutorial out there on how to feed that data into influxdb?
Many thanks and best regards
Not that I am aware of, but I will send you via private message a few links and the Node-RED forum folks can probably help you along if you get stuck.
Hi @Globgogabgalab,
You can also use Telegraf for this if you want a more performant solution. I agree though Node-Red is the easiest! I am a massive fan!
Directory Monitor allows you to monitor a specific directory and reads any csv’s you wish to parse there before placing them in a separate directory
Hi @Jay_Clifford ,
Thank you very much for your help! I have checked out the documentation but I am still unsure how to enter the URL/IP and the username/password of the FTP server next to the path.
Can you help me out here?
Ah @Globgogabgalab, sorry that was my misunderstanding.
So there is currently no telegraf plugin which will allow you to read files directly from an FTP server. So i agree with @grant1 I woudl use node-red for the easiest approach and then use the InfluxDB plugin for node red to write that data to influxDB. Otherwise you would need to use the execd plugin of Telegraf and write a custom script to copy over the file and parse in telegraf. Note if telegraf can be run directly on your FTP server then you can use the directory plugin.
hello @grant1
Do you have an example? For node-red csv → influxdb
thanks
Hi @mikeanita Sure, I can post an example flow from Node-RED. Are you using InfluxQL, Flux, or SQL?
i have a nas with text files, this file i will send to my influxdb.
@mikeanita
Hello.
I don’t know these 3.
So text files are stored on my NAS.
These files are already stored for the format that Influxdb requires.
I am currently copying these text files manually into InfluxDB.
About file upload
“Line Protocol”
In the InfluxDB dashboard
Would like to pass them automatically into InfluxDB
Do you already have InfluxDB set up, and if so, which version are you running and can you share a sample query that you already have working?
Hello @grant1
No my telegraf is Working :grin::blush:
But one problem i have.
The inputs in the text files are in the fromat “milliseconds”
in witch place in the telegraf.config file
i can say the format is precision = “ms” from the input??
[[inputs.directory_monitor]]
  ## The directory to monitor and read files from.
  directory = "/www/Huber"
  ## The directory to move finished files to.
  finished_directory = "/www/Huber/writte"
  ## The directory to move files to upon file error.
  ## If not provided, erroring files will stay in the monitored directory.
  # error_directory = ""
  ## The amount of time a file is allowed to sit in the directory before it is picked up.
  ## This time can generally be low but if you choose to have a very large file written to the directory and it's potentially slow,
  ## set this higher so that the plugin will wait until the file is fully copied to the directory.
  # directory_duration_threshold = "50ms"
  ## A list of the only file names to monitor, if necessary. Supports regex. If left blank, all files are ingested.
  # files_to_monitor = ["^.*\.csv"]
  ## A list of files to ignore, if necessary. Supports regex.
  # files_to_ignore = [".DS_Store"]
  ## Maximum lines of the file to process that have not yet be written by the
  ## output. For best throughput set to the size of the output's metric_buffer_limit.
  ## Warning: setting this number higher than the output's metric_buffer_limit can cause dropped metrics.
  # max_buffered_metrics = 10000
  ## The maximum amount of file paths to queue up for processing at once, before waiting until files are processed to find more files.
  ## Lowering this value will result in *slightly* less memory use, with a potential sacrifice in speed efficiency, if absolutely necessary.
  # file_queue_size = 100000
  ## Name a tag containing the name of the file the data was parsed from.  Leave empty
  ## to disable. Cautious when file name variation is high, this can increase the cardinality
  ## significantly. Read more about cardinality here:
  ## https://docs.influxdata.com/influxdb/cloud/reference/glossary/#series-cardinality
  # file_tag = ""
  ## Specify if the file can be read completely at once or if it needs to be read line by line (default).
  ## Possible values: "line-by-line", "at-once"
  parse_method = "line-by-line"
  ## The dataformat to be read from the files.
  ## more about them here:
  data_format = "influx"
In the dashboard can make here:
