Hello all
i’m trying to cleanup a tag named instance to remove unnessary infos
user_input_delay_per_process,host=redacted,instance=1:31060\ <conhost.exe>,
user_input_delay_per_process,host=redacted,instance=1:15796\ <explorer.exe>,
to:
user_input_delay_per_process,host=redacted,instance=conhost,
user_input_delay_per_process,host=redacted,instance=explorer.exe,
user_input_delay_per_process,host=redacted,instance=conhost.exe,
i tested on regex101, the pattern had what i want
[[processors.regex]]
namepass = ["user_input_delay_per_process"]
[[processors.regex.tags]]
key = "instance"
pattern = "<(.+)\.exe\>$"
replacement = "${1}"
but when i run telegraf it throw me an ** invalid TOML syntax** on the line of the pattern
i tested a simple one and no invalid TOML syntax
pattern = "(.+)"
any lights?
